fuel injector o Ring replacement????
Old Nov 9, 2003 | 08:54 PM
brabe's Avatar
brabe
Question fuel injector o Ring replacement????
I have a 95 psd with 98000 and was getting a some blue smoke from the exhaust and also found a lot of black crud in the bottom of fuel bowl and decided it might be time to put orings in.
Was wondering how big a deal it is for the home mechanic? I have read you have to dain the cylinder head of oil before you install the new ones.??? Also, I have heard i need an injector puller or installer???. Any tips or advice would be helpfull .
Thanks
Ford Forever!!!
Old Nov 9, 2003 | 10:43 PM
catmech's Avatar
catmech
Lightbulb
black stuff in fuel is sounds like algee.stick your finger in it and if its slimey its algee.this will plug fuel filters and cause low power.boicid makes a cemical you can put in the fuel tank to treat it.i would try this first.
Old Nov 9, 2003 | 11:56 PM
greg_23805's Avatar
greg_23805
If you have done a lot of your own mechanic work, internal engine work, then you can change the orings. I've done a lot of it and decided to do my '96 a couple years ago. At least get a Chilton's manual on the truck before you start.
You don't need a special puller if you are careful. I used a 1 1/2 inch wide, flat nail puller with a block of wood under it to pry against the edge of the head where the valve cover bolts to. Be careful and take your time as you work each injector out.
Yes you have to drain the oil and fuel rails out first but you will still get some leakage into the cylinders. This is the scariest part, you have to make sure you get everything out of the cylinder before you put the injectors back in. I used a vacuum pump and a small tube, you can use compressed air and blow it in and force everything out too.
This is a time consuming job but if you are up for it, you will save a $1000.00 of labor. Took me about 8 hours total.
If you are using 2 quarts or more of oil every 5k miles, the oil filter is black and that crud in the bottom is black, you might suspect the orings. If they have never been replaced, probably a good thing to do soon because they are likely to fail.
Old Nov 10, 2003 | 06:47 PM
brabe's Avatar
brabe
Is there any way to test fuel injectors to make sure they are funtining properly while i have them out to do the oring change
How do you make sure there is no fuel and oil in the cylinders??isn't is hard to see through the fuel injector hole to make sure???
Thanks
Old Nov 10, 2003 | 07:33 PM
greg_23805's Avatar
greg_23805
You need to have the injectors tested by a shop that knows how to test them, very specialized.
You can't see in the cylinder, you have to assume there is oil/fuel in there. All of mine had some and some had quite a bit.
I would not recommend that you change your own orings unless you are really experienced at mechanics. This is not a simple or easy job to do.
Old Nov 10, 2003 | 10:42 PM
International Tech's Avatar
International Tech
on draining the oil from heads, you can do 2 things. You can remove the plugs(either one) from the cylinder head and make a gigantic mess of oil on your garage or carport or when you remove the valve covers you will see 2 allen head plugs between the injectors (toward the valleyof the engine). Remove those 2 plugs on each head and let the oil drain completely. Remove each injector and replace o-rings. Before you start her up to avoid busting tips on injectors you can unplug the CPS and spin her over until you get good oil pressure. After that plug sensor in and start her up and drive away.
92bruiser
Oct 1, 2011 04:44 PM
JD4520
Mar 7, 2009 09:56 AM
kevbits
Nov 13, 2007 08:22 PM
mike manglos
Feb 18, 2007 05:28 AM
paulg
31
Jun 25, 2001 04:33 AM
