Test Fuel injectors
Old Nov 13, 2007 | 07:31 AM
kevbits's Avatar
kevbits
Test Fuel injectors
I think i keep getting air in my fuel system. I allready have the fuel injector install kit (not installed yet) but befour i do that, does anyone know if or how you can check the fuel injectors to see if they are working properly. I dont want to change all the o-rings and injector tops to find out latter that it was a bad injector or something the hole time.
Thanks,
Kevin
Old Nov 13, 2007 | 09:38 AM
PLC7.3's Avatar
PLC7.3
Take them out and take them to a diesel shop they can test them.....you already have the new copper seals in the kit for injector install. Make sure the old seals are out..........
Old Nov 13, 2007 | 08:22 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Also be carefull with the injection lines.
They tend to stick in the nuts when you loosen them which can result is a kinked line.
And be very careful when you move them around the injector, they don't like being bent.
Renneberg
Aug 3, 2014 10:47 AM
Onus
Jul 16, 2012 02:37 AM
PeterTheWolf
2004 - 2008 F150
Apr 26, 2012 03:57 PM
danielwd
1983 - 2012 Ranger & B-Series
Jan 2, 2011 10:18 PM
LIGOOMBA
Nov 10, 2008 08:39 PM
