P2291 code pending, no start
Old Jun 19, 2022 | 10:30 AM
vic89's Avatar
vic89
6th Gear
I'm working on a 2020 f350 6.7l, with a family member who ran it dry. We put in a diesel to to give it a quarter tank. Replaced the fuel filters to see the condition and hope it would help it start. When I check the pressures for the high at KOEO it reads just over 3000psi, the low side reads just over 30psi. When cranking the high side reads just over 5000psi and low side at around 73 psi. We were able to start it for a few seconds before it cut out and haven't been able to get it to completely start. We've visually checked fuel flow to the HPFP and it is present. I don't believe it the HPFP that has gone bad with just under 45000 miles. P2291 is pending and a P0087 is permanent because a roadside service guy loosened the line fitting to two injectors and didn't tighten them up. I checked all line fitting for tightness to be sure none are loose. Any ideas where or what to check before taking the intakes off to check the HPFP?
Old Jun 19, 2022 | 10:43 AM
scott91370's Avatar
scott91370
FYI - You posted this in the F150 section not the Super Duty.
Old Jun 19, 2022 | 10:52 AM
vic89's Avatar
vic89
6th Gear
Okay didn't realize, thank you.
Old Jun 19, 2022 | 11:17 AM
JKBrad's Avatar
JKBrad
Moved to the proper forum.
Smokin.6.0
Oct 31, 2017 09:11 AM
grileyh
May 31, 2014 10:43 PM
Dstosh
Jul 27, 2011 08:33 PM
shark1979
20
Mar 31, 2009 04:03 PM
ranger clone
Sep 6, 2004 08:14 AM
