2003 F350 won’t start
Old Oct 15, 2017 | 01:58 AM
Smokin.6.0's Avatar
Smokin.6.0
8th Gear
Pretty new to the diesel scene. Has egr delete kit, 175cc/30% injectors, and sct livewire tuner with custom tunes. Bought it about 2 months ago. It had a code getting thrown for injector #6 high voltage(P0277). It threw another code for injector #4 high voltage(P0271) about a week ago. Now it won’t start just cranks and cranks. It does sound like it wants to start but it won’t hold an idle. When it does start it idles really rough and almost sounds like it loping. When I drive it down the road it only hits about 40 mph. I changed the oil, oil filter, and the fuel filters. Tested the FICM and has a steady 48v. Changed the ficm harness. At this point Im lost on what else it could be. Anyone have any ideas?
Old Oct 15, 2017 | 04:12 AM
Yahiko's Avatar
Yahiko
Return it back to stock tuning. That males things act the way they should
and then we can start the testing, Other wise things can be a bit funny,
Also can you post the code numbers from before?
Old Oct 15, 2017 | 06:20 AM
darrellbarnes's Avatar
darrellbarnes
And make sure to keep your batteries charged up while you're at it. Lots of cranking can lead to lower voltage and kill your FICM.
Old Oct 15, 2017 | 11:20 AM
Smokin.6.0's Avatar
Smokin.6.0
8th Gear
I’ve been keeping it charged. Always watching the batteries because I heard those could really kill all the trucks systems. What codes do you want me to post?
Old Oct 15, 2017 | 03:14 PM
navistarnut's Avatar
navistarnut
Still possible it's the logic side of the FICM, but here is a good thread where Rusty has some checks you can do.
https://www.ford-trucks.com/forums/1...271-p0277.html
Old Oct 15, 2017 | 04:48 PM
Yahiko's Avatar
Yahiko
Any that have showed up.
Old Oct 19, 2017 | 09:43 PM
Smokin.6.0's Avatar
Smokin.6.0
8th Gear
Update: Did a buzz test and 3 injectors were out. Started replacing with stock size injectors. Just ran a buzz test after finishing the install of the driver side injectors and it’s throwing injector #6 circuit high. I’m going to look into a bad ficm next.
Old Oct 19, 2017 | 11:11 PM
Yahiko's Avatar
Yahiko
Take a 2nd look at the injector plugs and then remove and
reinstall the plugs on the FICM.
Old Oct 29, 2017 | 11:16 AM
Smokin.6.0's Avatar
Smokin.6.0
8th Gear
Finally got some time to work on the truck. Got all the injectors replaces and checked the wiring. Don’t have any codes thrown and they all pass an injector buzz test. Now I’m not getting any fuel to the upper fuel bowl. I replaced the fuel pump but I’m lost. Any help would be much appreciated.
Old Oct 29, 2017 | 11:41 AM
navistarnut
Injectors are getting replaced with Ford remans?
Were you not getting fuel to the upper bowl before, or after the new HFCM?
Old Oct 29, 2017 | 03:45 PM
Smokin.6.0's Avatar
Smokin.6.0
8th Gear
Replaced the hfcm and got the truck started. It’s running 10x better then before but when I drove it down the road it acts like it’s in limp mode. Won’t go over 30 at wot and the turbo barks when I let off the throttle.
Old Oct 29, 2017 | 09:52 PM
BLADE35's Avatar
BLADE35
Lots of parts throwing here
Test verify
Have a gauge for live datadata??
Old Oct 29, 2017 | 09:57 PM
Smokin.6.0's Avatar
Smokin.6.0
8th Gear
All these parts come off a truck I have sitting in my yard so it makes it easy and cheap to do it.
Old Oct 29, 2017 | 09:58 PM
Smokin.6.0's Avatar
Smokin.6.0
8th Gear
I can read live data off my computer.
Old Oct 30, 2017 | 07:27 AM
xcrsp440's Avatar
xcrsp440
Parts truck? Did it run before you starting pulling parts off it?
