How to clean off old ignition points
Old Jun 17, 2022 | 11:37 PM
mOROTBREATH's Avatar
mOROTBREATH
I need to run an old engine briefly and the points are pretty old and corroded but I'd rather not replace them just so I can run the engine for 5 minutes and forget about it again.
What method/material do you guys use to spruce up an old set of points if you were in a pinch?
Old Jun 18, 2022 | 02:27 AM
seaves46's Avatar
seaves46
Try a nail file or some emery paper .
Old Jun 18, 2022 | 03:33 AM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
There exists a tool called a points file:
Amazon Amazon
However, sandpaper, nail file, or similar can work in a pinch.
Old Jun 18, 2022 | 12:59 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I was told in auto class that non-metallic files/boards (emery or nail files) embed tiny grit in point contacts, that subsequently become fused into "glass" in use. May not matter for a short test run.
Old Jun 18, 2022 | 06:52 PM
mOROTBREATH
Thanks for the feedback ya'll. I actually have one of those tiny metal files, didn't know it had a name. I'll try that, I just hope the points open enough to let it slide through.
Thanks again.
Old Jun 18, 2022 | 07:06 PM
raytasch's Avatar
raytasch
Believe Nothing
The points are spring loaded to the closed position so getting the file between the contacts should not be an issue. OTOH, if the points are welded together, they can be broken apart.
Old Jun 18, 2022 | 11:25 PM
mOROTBREATH
Luckily no they are moving, I just didn't take the time to check how far apart they go and funny enough I'm not familiar with points enough to remember; I've only worked with points one time before and that was 12 years ago when I set them up--never touched them again after that lol
tyrantsparky
19
Jan 22, 2014 06:40 AM
GOTH_TRUCKER
Aug 16, 2006 06:32 PM
tdwhiteIII
1966 - 1977 Early Broncos
Feb 16, 2006 09:46 PM
jwtaylor
Oct 18, 2001 06:06 PM
lew11998
Jul 27, 1999 06:13 PM
