Going for a Checkup
Old Jun 17, 2022 | 09:27 AM
Brotherbillstruck's Avatar
Brotherbillstruck
Going for a Checkup
I am having an issue with a belch of blue smoke on startup(I have been watching the recent thread). Also having the black cloud pulling away from a stop. If it is a momentary stop at a stop sign the smoke is not bad-stoplight equals smoke. I try to feather the throttle to minimize this. I am going to a local Diesel shop for a Diagnostic Tuesday. They said they would check over whatever it is that I have concerns about.
I can think of three things I want checked, but I don't want to miss anything for my $125. First, is an Uncompensated power balance for the injectors. Second, turbo operation ( installed a new stock Garrett this year) and Third, EGR function (not deleted).
Am I missing anything? I have not noticed any other issues. Truck fires off immediately hot or cold and gets up and goes. I do have ~75 psi fuel pressure and the needle pulsates a little. I had this down to my Glowshift setup not being the most expensive option out there but.... So any suggestions are welcome as to what to have checked. Thanks
Old Jun 17, 2022 | 10:09 AM
TooManyToys.'s Avatar
TooManyToys.
My Isspro fuel pressure using to "pulse". When disassembling my engine, I found one injector copper that looked a little "cooked", but not bad. Reassembled and now with a Glowshift fuel pressure gauge, no pulsing.
I would include a Relative Compression test too, while you're there, just to have the info.
I didn't have a code for my EGR valve, nor any indication of an issue when I had IDS. Changing it, though, cured by blue smoke issue.
Old Jun 17, 2022 | 10:46 AM
Brotherbillstruck
Thanks. Relative compression noted. I have been wondering about a leaky injector. I watch the EGR desired and EGR measured ( I think this is what they are) on my scan gauge and the values always seem close. There is a delay, but they seem to follow each other. That does not mean that there is not a delay in the actual function of the valve though I guess. Also Forscan shows no codes pending. I have also done the usual Map hose replaced-intake nipple cleaned. EBP sensor replaced(OEM) and tube cleaned.
I found my unison ring completely stuck so I thought the new turbo was going to eliminate the smoke- for a while anyway.
Old Jun 17, 2022 | 05:27 PM
FiveOJester's Avatar
FiveOJester
Have you watched your EBP and VGT% during operation? It should try and maintain 2.4psi EBP at idle once the truck is warmed up. Cold startup it begins at 3.4 and works its way down. I believe the Scangauge reads EBP in absolute pressure so you'll have to subtract the 14.7 for atmospheric pressure (varies based on your altitude, 14.7 is sea level).
My truck usually is running around 65-70% VGT to maintain the 2.4psi at idle. If you are out of whack that could indicate issues with the vanes or an exhaust leak of some kind. I accidentally indexed my turbo vane actuator rod incorrectly so the vanes wouldn't close all the way and I was getting super low EBPs and the VGT was pegged at 85% most of the time.
Old Jun 17, 2022 | 08:06 PM
Brotherbillstruck
Thanks. I will check out that EBP and VGT relationship. I have never watched the two together. Funny but I do see 85% when I first start up even with the new turbo.The VGT moves normally driving around. With the stuck unison ring it would not move off of 85% right before I did the swap. I had a problem getting the up pipes sealed until I loosened the bolts at the manifold. I think I sealed things up when I did that but who knows. I will watch the relationship. I think my Baro here is still 14.7 so I can subtract that.
Old Jun 19, 2022 | 09:54 PM
Brotherbillstruck
I went on a long run today and watched the ebp/vgt at hot idle 4 times. VGT was at 73% every time. The EBP varied slightly from 16.6 to 16.9( had 2 @16.9/1@16.6/And 1@16.8). My Baro is 14.3 so I was around 2.5/2.6. Is this close enough to the 2.4 number?
Old Jun 21, 2022 | 02:05 PM
FiveOJester
Yes that is close enough. Looks like that part is working correctly.
Old Jun 21, 2022 | 03:49 PM
Brotherbillstruck
Thank you 5-0
Old Jun 21, 2022 | 04:00 PM
Brotherbillstruck
UPDATE:
The shop did not have the software to do a relative compression test which was disappointing. I did get an uncompensated power balance test. The injectors are very healthy. It was a dead straight line EXCEPT for number 3. It was just ever so slightly up... not down. This may be the one causing my fuel pressure needle to pulsate. When I get time I am going to reseal injectors. At least on that side. The possible smoking gun (haha) on my smoke from a stop is that the EGR valve failed the test. Needs to be replaced. I will update when I get the new valve and do some runs.
Old Jul 7, 2022 | 06:13 PM
Brotherbillstruck
Just want to wrap this up. Had a chance to make a few runs with the new Alliant Power egr valve from Ed at Ficmrepair installed. The smoke at startup is now minimal and the black clouds from a stop are gone. I think the amount of smoke I have left can be attributed to the Atlas 40 tune on the ficm. and just the nature of the beast. Anyway, I am happy with the results. I went with the Alliant Power for the cost savings. I figure Ed will stand behind it if it decides to act up.
Old Jul 7, 2022 | 08:09 PM
LindenBruce's Avatar
LindenBruce
Nice. I have gone through three EGR valves so far since I bought my truck new late 2005. Those things just don't seem to hold up very well. B.
Poorboy04
Aug 31, 2014 09:38 PM
Brad Brown
6.4L Power Stroke Diesel
28
Jan 5, 2012 06:10 PM
jfralph
Oct 5, 2011 03:13 PM
cj5on44s
Jul 6, 2010 07:24 PM
rosco_p_coltrane
Jul 13, 2006 07:13 PM
