White smoke once in a blue moon!
Hey guys, I have a 2008 F350 diesel and once in a while it barks out a big white cloud! I just had it in the shop where they replaced the fuel pump, they had to lift the cab off! unreal! but they said they couldn't find anything wrong with it. They didn't tighten the clamp up on the bottom turbo hose either so when I got out on the highway and put some pressure to it it popped off! Nice laying on my back in the snow/salt putting it back on! If you have any ideas let me know. Maybe it is just a common thing?
white smoke could also mean that you have some moisture build up in your cac or it could also be EGR cooler related.
Based upon what you are saying I don't think it is anything to be concerned with right now.
As always watch all your fluid levels and as long as everything stays where it should I would not worry about it.
Good info guys! I will add some additive and watch the fluids for sure, I am glad it isn"t something really big ! It is not in the cleaning filter mode, but it sure goes into that mode quite often. Especially when pulling my trailer. It never went into that mode very often before but the truck had a servicing done a while back and they changed the computer at the shop and now it does it a lot!
No, I pour mine in to 20 oz bottles and add 1 bottle per tankful. 60 gal tank, normally pump around 50 gals. It's a little extra but I figure DK is cheap, fuel systems for this truck are not.
Thanks , I am eyeballing the FMC additive and sure I'm a little rich on the mixture but one friend has an 09 and he just dumps a whole bottle of aftermarket add. [12 oz.] to his 30 gal. tk. like me he fills up at the 1/4 tk level .$4.20 a gallon for diesel here inL.A. what are you paying in GA.?
