AC Issue With Extremely High Pressure
Old Jun 14, 2022 | 09:10 PM
TexasGuy001's Avatar
TexasGuy001
The AC wasn't blowing very cool air 66 degrees and was cycling. So, since I had half a can of freon I hooked up the gauges and added it to see if it would start cooling better again.
For a little while it was blowing cooler air at about 50 degrees but then it started cycling again. The low side was 50 psi and the high side was 430 psi. Also the pressure would equalize immediately after shutdown.
I've never had an AC system do this before. Is it a failing compressor and/or a clogged orifice tube or something else?
Old Jun 15, 2022 | 08:34 AM
jas88's Avatar
jas88
High side pressure is the first issue to address. Check your fan clutch. Spray the condensor with water from a hose and see what that does to the high side pressure.
Old Jun 15, 2022 | 10:09 AM
TexasGuy001
Alright, I'll try that quick test and see what happens.
The condenser doesn't seem plugged up. I generally wash it out to clear the bugs off a few times a year.
The fan seems to be moving air, but I'll looks closer at it.
Also, the AC wasn't blowing very cool air at highway speeds before attempting to top it off.
Old Jun 15, 2022 | 04:02 PM
jas88's Avatar
jas88
If the condensor air flow is not at fault, then it sounds overcharged.
Old Jun 15, 2022 | 11:19 PM
TexasGuy001
Appears to be a bad fan clutch. It's not spinning the fan very fast and spraying water on the condenser brought pressure down. IR thermometer showed 157 degrees on the condenser when it was 94 outside. Still not sure why driving on the highway wasn't enough airflow though. But might have been a tad low. Pressures were 30-35 low and 250 high.
Old Jun 16, 2022 | 09:57 AM
Hit Man X's Avatar
Hit Man X
You may want to recover what is in there, pull down, and recharge with the spec as it is overcharged now. I would pull the liquid line and inspect the FOT for Teflon debris from the compressor due to that high side being way up there. Also, pull blower and use some cleaning agent on that evap unless it is fresh.
My '96 specs 38oz of 134A, yours probably does too.
Old Jun 17, 2022 | 10:25 PM
TexasGuy001
The fan clutch replacement seems to have put things back to normal. I didn't really notice the missing sound of the fan the last few tines the truck was driven and didn't notice anything was wrong until trying to use the AC, but now that the fan is working the way it should that sound is back.
Those are good points. I don't think it is over charged now. I did let a small amount out though. It was only operated 3 short times for a few minutes when it wasn't working correctly. So, as long as it's working good like it is now I'm leaving it alone.
Old Jun 17, 2022 | 10:31 PM
TexasGuy001
Anyway, For those that have AC issues like this, definitely check or replace the fan clutch before assuming there are major issues.
frankiethethumper
1978 - 1996 Big Bronco
May 31, 2021 05:56 PM
genscripter
Aug 4, 2015 03:14 PM
tshrager
May 2, 2012 07:48 PM
tp4pdb
Aug 17, 2008 10:36 PM
Luzer27
Jun 1, 2005 11:04 AM
