Bad AC cycling switch?
Old Aug 17, 2008 | 04:55 PM
tp4pdb's Avatar
tp4pdb
I have a 2002 Ford Explorer with a 4.0 V6. The AC blows only slightly cooled air. The compressor cycles on and off every 10 seconds when the AC is on. Pressure readings with the manifold gauges hooked up and the AC running ranges from 18-45 psi on the low side and 95-100 psi on the high side. With the AC off both gauges register 75 psi.
I checked the connection on the cycling switch and it looked OK. Is it time to replace the switch or could it be something else?
Old Aug 17, 2008 | 10:36 PM
Bear River's Avatar
Bear River
Former ******
Depending on the temperature you tested at,t he pressure on the high side sounds low. At 90 degrees should be around 150 psi on the high side. The pressure needs to be checked against a temperature chart, the pressures required varies by the ambient temperatures.
rodneycrow
May 11, 2016 12:10 AM
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
Jan 3, 2016 08:48 AM
mushman
18
Aug 3, 2015 07:54 AM
mizzleman
Jul 13, 2015 04:07 PM
C-4
Aug 31, 2004 01:48 PM
