Ignition key won't turn
Old Jun 4, 2022 | 08:43 AM
fordman19762003's Avatar
fordman19762003
Twice in the last two weeks I've put the key in the ignition of my 2019 and it won't turn. Both times I pulled the key out and reinserted it a couple times then it worked. Anyone else had this happen?
Old Jun 4, 2022 | 08:58 AM
jimzpsd's Avatar
jimzpsd
Is the steering wheel turned? Sometimes if the wheel is turned it can bind against the lock mechanism, next time it happens try moving the wheel left or right and see if you notice it
Old Jun 4, 2022 | 09:49 AM
fordman19762003
The first time it happened I think it might have been from the wheel having a little bind on it. Yesterday the wheel was turned but had no bind.
Old Jun 4, 2022 | 01:13 PM
KU4OJ's Avatar
KU4OJ
Maybe a little graphite (lock lube) in the keyhole?
It's cheap!
Old Jun 4, 2022 | 01:54 PM
6.2caribou's Avatar
6.2caribou
Same key each time or different keys?
Old Jun 4, 2022 | 02:21 PM
Pbergmann's Avatar
Pbergmann
Our trucks don't have a wheel lock, at least my 2020 doesn't.
Try the lube fix.
Old Jun 5, 2022 | 08:16 AM
Desert Don's Avatar
Desert Don
Also try inverting the key. In the past I have had a Ford key that would work one way but not the other. This was after the vehicle was a couple years old so the key had a bit of wear on it. Marked it with nail polish on one side so I could tell which way to insert it. But that was on a 70’s something year model.
Old Jun 5, 2022 | 06:48 PM
fordman19762003
I tried both ways and it didn't make a difference
fordman19762003
Same key. I figured if it starts doing it on a regular basis then I'll switch keys and see what happens.
snavemit
Dec 1, 2010 11:42 PM
FordRv1981
Nov 8, 2010 09:42 PM
CsChuck14
Jan 17, 2007 07:49 PM
brmpipes
Nov 30, 2006 01:04 PM
kymberlyee67
Apr 21, 2003 09:52 AM
