Ignition key won't turn
Old Nov 6, 2010 | 07:14 PM
FordRv1981's Avatar
FordRv1981
I have a 1981 Ford Motorhome Econoline and the ignition switch lock won't turn. Anyone have any help that they can provide on what to do to fix the problem. Thanks.
Old Nov 7, 2010 | 06:41 PM
WVVan's Avatar
WVVan
I have a similar problem. This works for me. After inserting the key, back it out just a hair, and I do mean a hair.
Old Nov 7, 2010 | 07:23 PM
shorebird's Avatar
shorebird
Are the wheels cut over hard? Try shaking the wheel left and right while turning the key. Try some lubricant in the key way.
Old Nov 7, 2010 | 07:51 PM
FordRv1981's Avatar
FordRv1981
Thank you and the other responders. I have tried the lubricant and moving the steering wheel and pulling the key out a bit. If I don't get it to work I have to see if there are instruction on how to fix the problem. Thanks.
Old Nov 8, 2010 | 03:52 PM
econoshorty's Avatar
econoshorty
Originally Posted by FordRv1981
I have a 1981 Ford Motorhome Econoline and the ignition switch won't turn. Anyone have any help that they can provide on what to do to fix the problem. Thanks.
Is in the column or the dash ? A new switch is a cheap and easy way to see if ithe switch is bad.
Old Nov 8, 2010 | 09:42 PM
FordRv1981's Avatar
FordRv1981
Ignition Lock Switch
Thank you for responding. It is on the steering column and I replaced the ignition cylinder today. It worked and I can now turn the switch on to start the engine. Thank you all for responding.
Lauren Fortier
Jan 13, 2016 09:46 AM
BobbyB
20
Jan 13, 2016 02:51 AM
hoss1981
Modular V10 (6.8l)
Apr 26, 2012 09:09 AM
Kalashnikov
Apr 17, 2008 10:20 PM
Stephen_E
May 9, 2004 01:50 PM
