Cannot Turn Key in Ignition
Old Dec 1, 2010 | 04:36 PM
snavemit's Avatar
snavemit
I went out to drive the Ex and the key wont turn in the ignition. I drive the car everyday and drove it earlier today. Any thoughts?
Thanks
Tim
Old Dec 1, 2010 | 04:46 PM
chazman's Avatar
chazman
try pulling the steering wheel one way or the other. Sounds like the wheel has the pin in the column pressure on it. Just giggle the wheel while turning the key. i do it all the time when I park with the wheel turned toward the curb .
Old Dec 1, 2010 | 05:04 PM
IanR's Avatar
IanR
See if the wheel is up tight against the lock. Turn the wheel a little off of the stop and you should be able to turn the ignigition, or are you sure it's the right key or maybe it's someonelses ex in your driveway.
Old Dec 1, 2010 | 06:08 PM
dvldog458's Avatar
dvldog458
Yeah give that wheel a tug left or right while trying to cycle the key. Mine does it every so often too.
Old Dec 1, 2010 | 10:10 PM
delano0512's Avatar
delano0512
That happends everynow and then the above suggestions work. If not then "houston we have a problem"
Old Dec 1, 2010 | 11:42 PM
EXv10's Avatar
EXv10
If the above ideas don't work your key or tumblers might be worn out. Try another key and then get some advice from your local locksmith.
tim432
Nov 17, 2011 05:07 AM
timmygyu
Aug 11, 2011 09:39 PM
tim.beery
Nov 28, 2007 07:20 PM
soberman41
Jul 5, 2001 12:24 PM
