Screeching sound while idle/driving.
Old Jun 13, 2022 | 10:46 AM
udsuth78's Avatar
udsuth78
Originally Posted by L-ight
Hmm.... I'll have to check that later today. I want to say it chatters until the engine stops rotating after the ignition is off. You can feel the chatter through the cabin. Engines do turn a bit more after the ignition is off, correct? Like half a rotation or so.
However long it takes for friction to overcome momentum. The torque convertor has some innards that would/could continue spinning briefly after shutdown I suspect.
Old Jun 21, 2022 | 10:39 AM
L-ight's Avatar
L-ight
So I removed the flex plate cover and didn't really see anything that seems wrong. Video being posted soon.
​​I did notice that when I put the truck in reverse the sound seems to worsen, therefore, in thinking it may be early signs of torque converter maybe?
https://youtube.com/shorts/B0DU6aozKQM?feature=share
Old Jun 22, 2022 | 10:38 PM
SteveZ's Avatar
SteveZ
Since the noise sometimes continues for a few seconds after you shut the engine off it is worth checking the turbo.
Old Jun 24, 2022 | 11:03 AM
L-ight's Avatar
L-ight
Yea, though the sound comes from underneath and sounds too heavy (if that makes sense) to be turbo noise. Though, I have been getting a hum during driving when I lightly let off the pedal. Once I give it throttle again the hum goes away. I'm thinking turbo, but I do have a SB Cai as well.
Old Dec 1, 2022 | 07:38 PM
L-ight's Avatar
L-ight
So I wanted to update the thread on my problem. I finally figured it out. Fortunately, it wasn't the flex plate or torque converter. It was an exhaust hanger that was rubbing/scraping against the frame rail on the passenger side of the truck. I guess my 4" exhaust finally settled after a year which caused this. So for a temporary fix I stuck two 1/4" thick felt pads that protect floors from furniture and shoved them in there. So far I haven't heard any rattles/scraping again. Such a relief as it was pretty embarrassing driving around with that loud rattle and screeching.
Old Dec 3, 2022 | 11:32 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Thank you for following up with the fix! Might help others with similar problems in the future.
Old Dec 6, 2022 | 04:10 AM
FordTruckNoob's Avatar
FordTruckNoob
How to "persuade" your exhaust to stope rubbing on the frame rail.
Old Dec 13, 2022 | 09:22 AM
L-ight's Avatar
L-ight
Can you explain more in depth on this picture? Is this bending it?
Old Dec 13, 2022 | 10:29 AM
udsuth78's Avatar
udsuth78
Some call it massaging, others call it persuading but yes it's bending. That there is a hydraulic flange spreader hooked most likely to a "Porta Power" hydraulic hand pump.
kyle j
43
Dec 27, 2016 08:12 PM
Dank Hill
Apr 25, 2016 02:32 PM
LOFD
2004 - 2008 F150
Jan 25, 2010 06:29 PM
FordCowboy2000
1997 - 2003 F150
Jul 17, 2003 12:09 PM
Ken2600
Oct 3, 2002 07:31 AM
