I can't figure this one out. I've developed a screeching sound and sometimes followed by a rattle when the truck is idle (in park) and sometimes when driving. We can rule out a few things here since the same sound happens both driving and idle. Now this doesn't happen every time I drive it. It's random. I was able to record a video of it when it was making the sound. Any ideas?
I'll second that, closely inspect everything related to the serpentine belt. While belt is moving and when not running. Remove tension on belt and wiggle pullys etc.
Check the belt drive assy. Maybe some chatter in the AC clutch.
That AC condenser run off is legendary!
It also makes this sound when the AC is off too. Yea I live in Houston so being hot and humid I pretty much run my AC at full blast anytime I am in the truck haha. I will check the pulleys and look for any movement. If there is movement then it's likely the pulley bearing is bad?
My unwritten rule is they should feel and spin smooth and silent. Any dragging, tight spots, or growling is time to replace. If you're in a pinch sometimes you can pop the seal out, pack a little grease in, and reinstall the seal. If it's just a dry bearing, that will usually fix it for quite awhile. Everything in life is better with the proper amount of lubrication.
With the belt removed rotate each pulley by hand while putting pressure on the pulley during rotation. If there’s a bad spot in the pulley you can sometimes feel it when rotating.
The bearings in these pulleys are the same and can be replaced easily without buying new pulley assys. However, buy the first set then you have time to rebuild the original set at your convenience, ready for swapping when you replace your belt.
Alright will keep that in mind. Also probably a good time to replace the belt and do the coolant tube bypass for the belt so I don't have to remove the coolant tube each time I need to change a belt.
Use a mechanic's stethoscope, you will know instantly when you touch the offending bearing/pulley (well, don't touch the actual pulley, but a stationary piece of metal near it).
What are the possibilities that it is the flexplate that is broken?
Fair odds to tell the truth. It's a somewhat common issue for the flexplate to crack between the bolt holes. I've read threads where guys have had 2 and 3 factory flexplates fail. There are aftermarket options available from factory replacement, to API upgraded, and full billet parts. Torque converters fail also, I at least mine did. You could start by pulling the inspection cover to see if you have play or if it has a wobble at idle.
So I went and tightened all the bolts for the exhaust brackets and I also saw part of the bracket where it was hitting the frame. So I added some padding in between the bracket and frame. Took it for a test drive. So far so good, but only drove it around the block. If it comes back I will remove the flex plate cover and check out the plate and see if I see anything.
That's a plausible cause for your mystery noise. My daughter's Jeep Liberty TDI had that issue with the cat tagging the frame rail until I massaged the exhaust with a pry bar then glued a split piece of hose over the edge of the frame. Simple and cheap, my favorite kind of repairs.
This morning I was able to get a better pin point of the sound (I think). I went and listened between the cab and bed from the top and that's where it sounded the loudest. I'm thinking that it could very well be a flex plate issue. I can hear the chatter from inside the cabin too. It also continues to chatter when the trucks is turned off for about half a second. I haven't had a chance to remove the flex plate housing yet, but will sometime this week and I'll report back. Anything I need to look for in there with the housing off?
Is this AFTER the engine has stopped moving, or BEFORE? If it's after, the only thing that will still be moving is the turbo.
Hmm.... I'll have to check that later today. I want to say it chatters until the engine stops rotating after the ignition is off. You can feel the chatter through the cabin. Engines do turn a bit more after the ignition is off, correct? Like half a rotation or so.
