Squeaky belt
Old Dec 21, 2016 | 04:01 PM
kyle j's Avatar
kyle j
Squeaky belt
1997 f350 205k All pulleys, water pump replaced along with belt about 50 miles ago. Think the only ones I didn't replace were ac pully and power steering pully. Trucks sits for weeks on end. Every time I start it and take it for a drive the serp belt has a loud sqeeking that's constant. Doesn't matter if wet or dry out and doesn't go away after trucks fully warm which I figured it would? Any ideas? I might just be being over picky but it's obnoxious haha
Old Dec 21, 2016 | 06:45 PM
oldbird1965's Avatar
oldbird1965
I had squeaky belts until I did this. Of course it could be your ac pulley and or PS.
https://www.ford-trucks.com/forums/1...rade-pics.html
Old Dec 21, 2016 | 07:43 PM
kyle j's Avatar
kyle j
Hey oldbird, ya I ended up doing that mod to my last 97 several years back iirc the idle pully and tensioner had enough tension on them that they were grinding into each other wish I still had the pictures. Napas new updated tensioner pully I installed has a longer arm to correct this issue. I'm woundering if just the lack of driving it (maybe 20 miles a week) has somthing to do with it? Might switch it up and drive the old girl all over this week see if it gets any better
Old Dec 21, 2016 | 08:26 PM
97-psd's Avatar
97-psd
Did you check the AC pulley when you replaced the others? If not then I would pull the belt, and check them just to make sure. I had an annoying sound like that and it is a wonder mine didn't fly apart
Old Dec 21, 2016 | 08:31 PM
97-psd's Avatar
97-psd
With the clutch off you can see how bad mine was. When I started to remove it the ball bearings just fell in the floor
Old Dec 21, 2016 | 08:43 PM
oldbird1965
I had that problem that Ben had also. Last summer I had a 'chirping' noise and it turned out to be the vacuum plumb. For the tensioner I bought a motorcraft one from Riffraff.
Old Dec 21, 2016 | 10:06 PM
kyle j's Avatar
kyle j
Damn yea suprized that did come apart. I'm not sure If i did check it but while trucks running there's no visible play in the Ac or ps pullys but I will pull the belt and wiggle them around.
Old Dec 22, 2016 | 06:24 AM
Frank250Tank's Avatar
Frank250Tank
I am battling a squeek issue too, Ive replaced the tensioner and the issue still persists.. It sounds like its coming from the passenger side of the engine..
I sprayed WD40 on various pulleys with no effect... This squeek is going to drive me nuts
Old Dec 22, 2016 | 08:13 AM
knottyrope's Avatar
knottyrope
Our sienna van had a squeak for many years and I gave up on it then a recall came and they replaced the crank pulley since the rubber would separate, no more squeaks.
Old Dec 22, 2016 | 10:32 AM
kyle j's Avatar
kyle j
Well think I just figured it out went out and bought some lubricating spray and sprayed mildly to the Ac pump pully and the sound stopped then came back after a few min. How hard is it to replace? Thanks
Old Dec 22, 2016 | 10:59 AM
kyle j's Avatar
kyle j
Is this all I need seems pretty straight forward? Couple bolts and a pigtail holding it together?
Old Dec 22, 2016 | 11:06 AM
knottyrope's Avatar
knottyrope
I don't see a bearing in the pic, hopefully it comes with one
Old Dec 22, 2016 | 11:13 AM
kyle j's Avatar
kyle j
yea hoping it's pre installed I would have to take a look while I'm there
Old Dec 22, 2016 | 12:41 PM
kyle j's Avatar
kyle j
Anyone know if the pully needs to be pressed on or off? Or just remove the belt, remove center bolt, unplug pigtail and out it comes?
Old Dec 22, 2016 | 12:56 PM
knottyrope's Avatar
knottyrope
its a splined shaft in the pic above, might just come off easy or not
