Bypassing ac
Old Mar 25, 2016 | 10:41 AM
Dank Hill's Avatar
Dank Hill
Bypassing ac
Ok I have a bad belt squeal I believe may be caused by a bad ac clutch/bearing.
I removed the belt and turned ac pulley and can hear a kind of scrubbing sound. The squeal goes away If You put soap on the belt so I'm not sure it's the ac or not.
But the soap is starting to make a mess of my engine and I'm getting tired of having soap the belt up before every drive.
My question is can I bypass this without removing the ac clutch or compressor, can this be done with just a shorter belt?
Also is it likely it is the AC(which doesn't work). I have replaced the tension and put two new belts, cleaned the pulleys numerous times, replaced alternator I'm stumped.
Old Mar 25, 2016 | 12:38 PM
DeathRangerofDeath's Avatar
DeathRangerofDeath
If you don't want to fix the a/c, you can usually buy an a/c elimination bracket that removes the compressor and replaces it with an idler pulley. Check out rock auto..
As far as shortcuts, you need to post up what vehicle and engine you're talking about if you want specifics.
Old Mar 25, 2016 | 01:07 PM
Dank Hill's Avatar
Dank Hill
88 xlt lariat 5.0 302.
I want to know if it is the ac making the squeal before I make any repairs
More info
The squeal starts as soon as the truck starts changes in pitch and sound depending on weather, sometimes it squeals really loud.The squeal is constant and it seems get higher with increase in spede and sometimes the sound won't go away until the truck goes from 1st to 2nd after putting soap on the belt.
Old Mar 26, 2016 | 04:18 PM
DeathRangerofDeath
Well if it's a constant squeal, it's pretty easy to track down. Get yourself a length of hose (garden, heater, whatever), and while it's squealing put one end of the hose to your ear, and move the other side around. It'll be obvious where the squeal is coming from. Try not to get sucked into the belt.
Also, have you tried a different brand of belt? I've had more than 1 that squealed no matter what I did, until I tried a different brand. I've got a Goodyear Gatorback on mine right now the squeals for a second every startup right now I've been meaning to replace.
Last edited by DeathRangerofDeath; Mar 26, 2016 at 04:19 PM. Reason: failure to chooch the spellings
Old Mar 26, 2016 | 06:03 PM
Dank Hill's Avatar
Dank Hill
I tried the dayco and I think the other was a nappa belt.
I thought maybe the pulleys where glazed but I cleaned and sanded them down and the noise came back.
I don't care about fixing the ac if it is causing the noise but I'll go try that hose thing right now to see if I can track it down.
Old Mar 26, 2016 | 06:49 PM
Dank Hill's Avatar
Dank Hill
The hose didn't work the sound also decided to be intermittent today.
Old Mar 27, 2016 | 11:56 AM
Dank Hill's Avatar
Dank Hill
Bump.
Bump bump.
Old Mar 28, 2016 | 02:10 PM
Dank Hill's Avatar
Dank Hill
Does no one have solution?
I figured this would be a fairly simple fix.
I have bought a belt that is 84 5/8 but I'm not sure if that is correct m. Someone please help me resolve this annoying squeal.
Old Mar 28, 2016 | 02:45 PM
Lead Head's Avatar
Lead Head
If soap makes it go away it's not the AC compressor pulley bearing making the squeak. You either have a bad idler bearing causing a pulley to be tilted, or your pulleys are no longer in alignment.
Old Mar 28, 2016 | 02:55 PM
Dank Hill's Avatar
Dank Hill
I also took that possibility into consideration. But the idler pulley/tensioner is new if that means anything
Although they look all in line except for the smog pump going to the crankshaft looks like it could be off a bit. Which was my second guess
I had saw a diagram online where I could bypass the smog pump and the ac using the same length of belt.
I figured if it wasnt the ac I would just bypass both of them
But it doesn't look like the length was accurate r
The belt in diagram was 84.5 inches I got a 84 5/8 thinking it was close enough.
Old Mar 30, 2016 | 08:28 AM
Dank Hill's Avatar
Dank Hill
Bump so if it's not the ac bearing what is my next step to resolve this. And where should I check if the pulleys are out in alignment.
The truck didn't squeal when I bought so I'm not sure how a pulley can just come out of alignment or become tilted. Also like I said the tensioner pulley is new not sure if that the same thing as the idler pulley
Old Apr 25, 2016 | 02:32 PM
green_95's Avatar
green_95
Well took it to a shop after work. He hooked his machine to it and put a vacume on it to check for a leak. He said it didn't have a leak and he attempted to charge it but it still wouldn't get cold. He said for $400 he'd put a new not reman compressor,dryer and orifice tube. Ouch I wasn't expecting that much.
Future_LEO
Modular V10 (6.8l)
Sep 19, 2011 09:02 PM
stupidjet
Apr 12, 2010 10:17 PM
fordff
15
Oct 7, 2008 05:25 AM
XXL Supreme
Mar 9, 2007 12:17 PM
03eddie
Jun 23, 2006 11:38 PM
