Well That Sorta Sucks...
No such items exist on the superduty and I have read no such plans exist currently to offer a hybrid SuperDuty.
Best you could do on a superduty is to get the trans with the PTO option and get a generator that runs off of a PTO, which im not sure any actually exist, but ive never researched that to much.
That being said, I'm sure if they build a hybrid super duty, it'll sell.
Or you buy the integrated generator and just drive the truck. The truck's powertrain components are also rated for a lot higher duty cycle than most portable generators. Get something commercial-grade and the costs and weight go up with the capability.
Regarding your 1850 lb Lariat; the SuperCrew Powerboost 4x4 in the base XL configuration with no additional options has a maximum of 1830 lb payload according to Ford. Based on that, you must have missed the powerboost (PB) notation in my post.
Boats and standard travel trailers are probably much less likely to have that much overkill on tongue weight.
I found your post regarding F150 payload very helpful- Thanks.
Your estimate came relatively close- excellent understanding of the system or a little luck?
If you don't mind, a few questions.
Where did you get the Bed Utility 73#? From the Ford guide, I get around 49#- Cleats and tailgate step.
20" wheels 34#/wheel seems steep. Power seats 13# total or each?
Ford certainly does not make it easy.
I am using the information to approach the problem from a different direction.
I have contacted 5-6 dealers to get door and window stickers for Powerboost F150 on their lot.
So, I am taking the actual PayLoad and adding unwanted features back in.
4x4 260#, moon roof 64#, Skid 28#, Bed utility 49-73#= 401-425#
Example: Lariat High- 1401#PL- go to 4x2 and remove moon roof, FX4, Bed utility goes to 1802-1826
Since I am unsure about 18" wheels/tires- I am leaving that out to offset trailer mirrors.
Any clarification regarding Bed Utility? Wheels?
I am thinking- Powerboost, Lariat mid, 4x2, Max tow, Sport Package (says it allows 18" wheels), 360 Assist, 7.2Kw, tow mirrors- should come in some over 1800#. I am going to look for a dealer that can go through the numbers.
How is your truck doing? What are you pulling?
Thanks,
Reid
I tried to send a PM, but was not smart enough. Anyone- how do you send a PM?
Thanks,
Reid
I used the weight information from a .pdf file available on the Gen14 forum:
https://www.f150gen14.com/forum/thre...tures-etc.202/
I don't remember how exactly I came up with the individual items in my list, I may have combined some and interpreted others from how they were listed in the 2021 reference .pdf file.
Edit: I looked at the file again and think I used an item called "Pick-up BoX Access Steps" which was 63#, but should have used "Tailgate Step" which is 40#. Adding in BoxLink Cleats and bed lighting was the additional 10#.
