But is it used to change parameters as the truck warms up?
If the coolant sensor on this van is similar in function to the Excursion, it's crap (as I sarcastically noted above). All it does is send a basic signal to the "gauge" on the dash, which is, really, nothing more than an idiot light masquerding as a gauge. There is no coolant temp input into the PCM.
I was experiencing a significant problem with oil temps while towing that I could not track down, only to find later that I was actually experiencing a large swing in coolant temps, which affected the oil temps through its intercooler/exchanger. Through it all, the "coolant temp gauge" never waivered, despite probably having seen coolant temps exceeding 235.
I'm told that my PCM uses oil temps for engine parameters. I now monitor that as a guide for problems with either. - GA
Most likely. The diagram shows one lead coming from the coolant temp sensor and going to terminal 37 for manual transmission engines, but the same lead going to 37 in automatics from the ATF temperature sensor.
Really? I thought the PCM uses transmission fluid temp (TFT) for calculations in AT trucks and coolant temp from that extra sensor in MT trucks. Not saying I'm right. Just asking for clarification.
My recollection is PCM uses oil temp on ATs, but since looking at the diagram I'm not sure.
I see the TFT feeds to pin 37 on the PCM like the MT coolant sensor does. Makes no sense for the PCM to decide engine fueling by reading the trans temps. So indirect. Oil temp is a good analog for coolant temp, but TFT? Pretty sure this is the same diagram Kwik has.
Dash gauge gets signal from the 10884 part I referenced above. That sensor fits into the water pump. That's only for the dash.
The PCM gets engine temp data separately. For AT trucks the data comes from an oil temp sensor (12A648) on the back of the HPOP reservoir. For MT trucks there is a sensor on the front cover near the CPS that reads coolant temp.
It is possible to select and view "ECT" on AT trucks with scanner, but the data is garbage. You must monitor EOT. But ECT monitored on MT trucks is the same as what the PCM sees.
Luckily Ford made it complicated so we could have this little chat.
And to go a step further and even complicate it more. Only 01 and up MT have the extra temp sensor.
Well, AT PCMs have different codes/calibrations than MT PCMs. TFT for PCM to control shift points on AT trucks and EOT to control fueling for MT trucks maybe? I bet @cleatus12r knows.
Its possible the ford dealer near my work gave me the wrong one, didnt bother double checking im just tired of taking the damn intake off every time to do anything. Im so far behind on racing prep for the season with work I wanted it to be the last time for at least a few months.
The one that I was looking at is the 2002 Superduty one available for download in the Tech Section. I found it much easier to read than the kludgy black and white versions that came with the Ford CDs in the past that looked exactly like the ones posted. The one that I found is colorized, much easier to read, and says basically the same thing as the B/W ones.
Google Drive link to the colorized one provided via the link in the Tech Section. https://drive.google.com/file/d/1npu...gvg4r0mtg/view
