This doesn't look good
Old May 24, 2022 | 01:24 PM
deanramey's Avatar
deanramey
This looks like it's going to be time consuming to repair.
Old May 24, 2022 | 01:30 PM
z31freakify's Avatar
z31freakify
Ouch! Try to JB weld it, if it doesn't work engine will have to come out to remove the timing cover, perfect timing for a re seal, and getting the heads freshen up.
Old May 24, 2022 | 01:38 PM
Walleye Hunter's Avatar
Walleye Hunter
Yep, like Adam said, front cover. Engine R&R+parts. How did that happen?
Old May 24, 2022 | 04:37 PM
deanramey's Avatar
deanramey
I was replacing the HPOP reservoir gasket to stop an oil leak and as I was just snugging up that bolt I heard it pop. Thanks for the JB Weld idea z31. I'll give that a shot first, it's definitely worth a shot. I really hope that works. I'm really not looking forward to replacing that front cover. I would hope the heads wouldn't need to be refreshed with only 130K miles on this truck. Though if I do have to pull the engine I will finally get around to installing head studs.
Old May 24, 2022 | 04:38 PM
PriusLover's Avatar
PriusLover
Looks like a L99 gasket with the screen was used?
I'd remove the cover and have a good welder fix it. Would likely cost much less than a new cover from Ford.
Old May 24, 2022 | 05:01 PM
deanramey's Avatar
deanramey
That would be the cause then, using the wrong gasket. Why does learning these lessons have to be so difficult?
crazyredneckanyhow
West Virginia Chapter
May 29, 2012 07:26 PM
Longrodder
Appearance & Dress-Up
Mar 8, 2008 08:39 PM
48fordcoe
Feb 18, 2008 10:36 AM
Red Star
Ford vs The Competition
30
Aug 4, 2006 10:44 AM
Pikachu
Florida Chapter
Aug 26, 2004 06:53 AM
