Trans Decel for towing
Old May 18, 2022 | 11:20 PM
derek0525's Avatar
derek0525
So what is actually happening to the trans when there is a decel option I know DP had it in their tow tunes but seems nobody else has it in their tunes is it a bad thing for the trans? It was a nice option in the tow tunes when i had DPs tunes. Was going to ask some tuners about this option but not really sure what its actually called. Torque converter lock decel?
Old May 18, 2022 | 11:29 PM
Bitterroot Diesel's Avatar
Bitterroot Diesel
Former Vendor
I believe Andrew Arthur will write a decel and ebpv tune.
Old May 18, 2022 | 11:37 PM
derek0525's Avatar
derek0525
Dont have an EBPV anymore. Sorry who is Andrew dont know any tuners real names just the business.
Old May 18, 2022 | 11:50 PM
Bitterroot Diesel
Former Vendor
AA design & performance tuning.
Old May 19, 2022 | 01:44 AM
FinnishStroker's Avatar
FinnishStroker
Decel tune keeps the TC locked up and coast clutch applied.
There are many variations between stock PCM calibrations,on how it's programmed to behave under engine braking situations.
Old May 19, 2022 | 01:51 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Like the Finnster said, the DP decel tune firms up the transmission so the compression drag of the engine is passed thru to the wheels to slow the rig. Big contributor to that engine drag is from closing the EBPV. Without EBPV it's far less effective.
Detractors will say it increases exhaust back pressure so much it can float the valves, potentially causing valve/piston contact. Which depends on condition of your valve springs.
Old May 19, 2022 | 11:01 AM
derek0525's Avatar
derek0525
Ya i didn't have an EBPV with the DP tunes either but it did slow the truck down pretty good with however they did the transmission programming. Be nice if they made tunes for Hydra that was one of the best tow tunes i have used so far. But other tuners beat them as far as other tunes go not saying the other tuners tow tunes suck I like the shift points guess best fix is to get a trailer with brakes.
Old May 19, 2022 | 11:40 AM
ScaldedDog's Avatar
ScaldedDog
If you don't have an EBPV, just press the OD off button on the stalk. In addition to keeping you out of OD - and downshifting if you are in OD when the button is pressed - it will apply the CC. If you are traveling above about 40mph the TC will likely be locked, too, and that's as good a decel tune as you can get without somehow blocking the exhaust. Also, and I'm sure you know this, any trailer of consequence needs brakes.
Mark
Old May 19, 2022 | 11:57 AM
derek0525's Avatar
derek0525
Ya i need to pull my steering column cover off and find the dreaded wire that blows my fuse when i hit the OD off button its been this way for about 3 yeats now should prob fix it only drive my truck once a month mostly so i have pushed it off. The trailer weighs prob 1200 lbs maybe and my sxs is around 2k not alot of weight but i do feel it.
cherrybomb37
Dec 12, 2013 11:38 AM
Robert6401
17
Feb 8, 2011 07:48 AM
fixit5561
28
Jul 17, 2010 08:15 PM
CobraGT40
May 19, 2009 03:34 PM
Workin4ALivin
Dec 30, 2005 12:09 PM
