kickdown bushing and retaining clip needed.
Old May 12, 2022 | 06:12 AM
i-w's Avatar
i-w
Question kickdown bushing and retaining clip needed.
78 F150 4x4 - C6 and 2150 2 Barrel Carb.
need the spring for the carb kickdown mechanism
retainer clip for kickdown at the Carb
possible to find the bushing for the kickdown rod.
would like to get the bushing for it if possible
BUT i Really need the retaining clip the most!!!!
i been searching but have not had much luck.
more than likely i probably entered the wrong
words in the search.
Thanks for the help.
Old May 13, 2022 | 08:23 AM
aldridgec's Avatar
aldridgec
I’ve been able to go to the hardware store and source what I need. I’m pretty sure it’s just a standard e-clip.
Old May 13, 2022 | 04:13 PM
DB429SCJ's Avatar
DB429SCJ
Yes ,regular e-clip. SPRING should be C5AZ-7B146-D. 2 11/16 free length. 21 3/4 coils. Bushing is part of kickdown rod. Check local junkyards.
Old May 14, 2022 | 10:35 AM
5851a's Avatar
5851a
Ford Kickdown Rod Bushing Replacement Kit- ALL Ford Kickdown Rods-NEW!
Old May 14, 2022 | 10:39 AM
5851a's Avatar
5851a
Sorry had to do 2 posts, look for this on ebay. Might be what you are looking for as far as a bushing and clip. Have never bought from or anything to do with.
Old May 14, 2022 | 02:03 PM
Sortofa65's Avatar
Sortofa65
Search for Kickdown rods galore and more. I've bought the bushings from them.
Old May 14, 2022 | 04:58 PM
DB429SCJ's Avatar
DB429SCJ
Update on that spring: D1AZ-7B146-A Mac's lists them. currently out of stock. That snap-in bushing looks like the right one. Some places are selling transmission linkage bushings as kickdown rod bushings. Not sure if those could be made to work.
Old May 22, 2022 | 05:49 PM
i-w's Avatar
i-w
I ended up buying a snapping kit form amazon.
Like 11 dollars. Has 300 in many different sizes.
Thanks for all the help.
tractoman
Mar 23, 2006 12:14 PM
elcapitan
Nov 18, 2005 06:06 PM
66sprintw53
Aug 17, 2004 09:59 AM
AceTrucking
Jul 9, 2003 10:51 PM
