Smog pump system
Old May 8, 2022 | 05:24 PM
junkyardjeff's Avatar
junkyardjeff
Smog pump system
I recently bought a 89 F 250 and that system has been messed with,the divertor valves must have went bad and replaced with pipes and the pipe going to the cat is gone. Truck has a serious hesitation problem when cold and still does not seem like it has full power when warm and it got me thinking it could be the way the pump system is now hooked up,with the air going to heads and exhaust manifolds at the same time could it affect the oxygen sensor making it not run right. If the pipe going to the cat was still there I would direct the air there but now thinking about getting a shorter belt and not having the pump working.
Old Jun 7, 2022 | 07:35 PM
junkyardjeff
Disconnecting the the air pump solved the hesitation problem,too much air going in before the O2 sensor.
jvossman
Sep 3, 2021 10:44 AM
rwmorrisonjr
Bronco II
Aug 23, 2005 09:35 AM
danielzink
1978 - 1996 Big Bronco
May 27, 2005 01:28 AM
JimMorrison
Dec 17, 2004 09:23 PM
jbalestri
Exhaust Systems
Mar 17, 2003 12:04 PM
