6.0 egr failure
Old May 2, 2022 | 06:34 PM
Trey6.0's Avatar
Trey6.0
6.0 egr failure
I have a 05 6.0 psd. What are signs of egr failure? My truck is studded and still seems to be losing coolant and truck isnt running right at all, a very big loss of power but the truck is NOT puking out the degas and no oil and water mix. Does blow a tiny amount of white smoke at takeoff and idle. someone told me that head gasket failure doesnt cause a big power loss so im thinking its egr failure, what do yall think?
Old May 3, 2022 | 09:44 AM
Striderwv's Avatar
Striderwv
Old May 3, 2022 | 06:31 PM
speedfreak78's Avatar
speedfreak78
Have you run the codes or done any computer diagnostics?
What other mods?
Old May 5, 2022 | 12:01 PM
redford's Avatar
redford
FTE Leadership Emeritus
Moved the 6.0L PSD engine forum.
Good luck!
Old May 5, 2022 | 12:12 PM
Brotherbillstruck's Avatar
Brotherbillstruck
You can park the truck nose down overnight.Next morning remove the EGR valve and look for coolant pooled in the intake. You can have some soot on the valve normally. If it looks steam cleaned or there is pooling of coolant the cooler is cracked. Just saw that Striderwv has you covered. All the info in his link.
Old May 6, 2022 | 02:09 AM
Trey6.0's Avatar
Trey6.0
does a cracked egr cooler cause performance issues? Like bad acceleration and poor drivability?
Old May 6, 2022 | 08:04 AM
Brotherbillstruck
I have not heard of any drivability issues with egr failure. If an overheat happens because the coolant loss is not caught then the bigger problems happen. A lot of us monitor engine temps and some have installed low coolant alarms. If you are having drivability issues then there are more than likely some stored trouble codes even without the check engine light. Forscan/Forscan Lite download is an inexpensive capable code retriever. You would need to get a compatible OBD reader for whatever type of cell phone you have. An android will require bluetooth while Apple will use a wifi version OBD link.
Dieseltechron is a great resource on YouTube as well as Srmastertech to help with the nuts and bolts of many issues.
Old May 7, 2022 | 10:19 AM
TooManyToys.'s Avatar
TooManyToys.
I would be more concerned that coolant going into the combustion chamber creates a very high steam pressure which can compromise the head gaskets.
Old May 8, 2022 | 02:08 AM
Fuzzpuss's Avatar
Fuzzpuss
If he's getting coolant in the combustion chamber, aren't his HG's already compromised?
Old May 8, 2022 | 10:18 AM
TooManyToys.
Not if it's coming from the EGR cooler leaking.
But if you mean with a leaking EGR cooler, do I think there will be ahead gasket issue later, yep.
Old May 8, 2022 | 07:12 PM
Trey6.0's Avatar
Trey6.0
i went ahead and got rid of the egr cooler. Still running the same. Theres no black smoke or anything. Injectors are new, it coded for ebp sensor, notised it was completely unplugged, plugged it in, cleared code and still dont run right. I also replaced the turbo and ipr. Im out of ideas. Was also coding for manifold absolute pressure.
Old May 8, 2022 | 07:35 PM
bismic's Avatar
bismic
Please post curent code numbers.
Please post MAP, EBP, and Baro at KOEO. All in PSI please.
Air flter "filterminder" reading ok?
Whose injectors did you install?
Old May 9, 2022 | 07:29 PM
diesel_dan's Avatar
diesel_dan
They're gonna' wear you out, brother.... Same chit is going on in other FTE forums, and other forums I'm on.... We are under some kind of attack?
DivertingRose1
Mar 31, 2020 03:14 PM
tahoe250
Jun 1, 2019 01:25 PM
PlatinumPSD
Nov 10, 2010 03:37 PM
tdark
Apr 10, 2007 03:15 PM
