Low Power
Old Nov 10, 2010 | 08:36 AM
PlatinumPSD's Avatar
PlatinumPSD
Low Power
Ok I have a 2005 f250 6.0 4x4 with 115000 miles. the truck will lose power and RPM goes to 1000 no higher in drive then in park it will rev up with a lot of gray somke not black. i can turn off the truck and start it drives fine or waite a few sec. and fine. Cleaned EGR it was bad is this my problem i am lost due to the gray smoke and and RPM at 1000 i did not see this in EGR threads.
Old Nov 10, 2010 | 09:41 AM
jmaskew's Avatar
jmaskew
Does the "Smoke" smell like diesel or coolant? When you cleaned the EGR Valve was it all wet and sticky, was there coolant inside the hole?
Old Nov 10, 2010 | 10:29 AM
PlatinumPSD
The EGR was black not wet more of a thick oil soot mix and i did not smell the exhaust but i did not see coolent.
Old Nov 10, 2010 | 10:54 AM
PlatinumPSD
There is a pic of the egr in my profile could not post it to the thread.
Old Nov 10, 2010 | 10:56 AM
npccpartsman's Avatar
npccpartsman
How long has it been since you changed fuel filters? Have you code scanned it??
Old Nov 10, 2010 | 11:02 AM
PlatinumPSD
Changed the filters thinking it would fix it no luck. No CEL but dont have a code reader. Will autozone pull codes for this truck, i know they can not on my 2001. and dont want to $100 at dealership.
Old Nov 10, 2010 | 02:19 PM
jmaskew's Avatar
jmaskew
Are you loosing coolant? I'm not talking a visible leak but do you need to fill up the degauss bottle once in a while? That sticky oily crud on your egr valve could be a mixture of coolant and soot.
Old Nov 10, 2010 | 03:29 PM
PlatinumPSD
had the truck for 5 mo about 25000 miles never added coolent and not low.
Old Nov 10, 2010 | 03:37 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Do the voltage check on the FICM.......https://www.ford-trucks.com/forums/9...procedure.html
MarkA4
Mar 12, 2015 09:34 AM
RealMenPowerstroke!
Aug 10, 2013 10:40 PM
willd
Mar 29, 2004 08:06 AM
tigerw72
Jul 14, 2003 06:33 PM
