Soft Start for A/C
Old Jul 2, 2023 | 05:16 PM
  #46
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
Originally Posted by johndeerefarmer
Maybe you should talk to Microair and learn how to unit actually works as opposed to implying that they will hurt your compressor and/or the Easystart is no good since it's universal and works on multiple units... Mine has had one on it since 2016 and been used in the hot Texas summers.... A/C and Easystart are still working..
Hard data good enough for you?
What hard data, just because you're is still working isn't hard data. Our 20+ year old Domestic 15K heat pump is still doing great with the factory start cap and relay and that I includes running it on a generator but we have a properly sized generator. So with your way of thinking that's hard data that you don't need one. Remember I did this stuff for a living.
I do have a true soft starting heat pump I just installed on our house (home base) but it has a inverter driven compressor not a standard single phase compressor, starts slow and ramps the speed up by increasing the frequency with a inverter on a specially designed compressor motor. It replaced a 23 year old heat pump that was still working and still had it's original start cap and relay so that's more hard data.
Denny
Old Jul 3, 2023 | 08:40 AM
  #47
travlingman's Avatar
travlingman
ActiveStart has came out with a 50 Amp plugin along with surge protection option.
ActiveStart with surge
Old Jul 3, 2023 | 09:14 AM
  #48
MBuckholz's Avatar
MBuckholz
My EasyStart has been in use since 2017. I can run my Coleman A/C unit on my Yamaha EU2000i up to around 4,500' feet elevation, above that the elevation derate catches up with me and I have to twin the yamahas. But the EasyStart definitely "stages" the start up of the A/C unit every time the compressor cycles on.
Old Jul 3, 2023 | 01:56 PM
  #49
travlingman
Here is a
of the new 50 amp ActiveStart where he takes the 50 amp plug to 30 amp and runs 2 AC's with a portable generator at the same time.
Old Jul 4, 2023 | 09:35 AM
  #50
cpobst's Avatar
cpobst
I just bought a Microair for our house A/C so my 12k generator will start it. Our 3500/4000 generator will run one 15k unit in our camper now but still
considering one just so it comes on easier.
Old Jul 4, 2023 | 10:37 AM
  #51
rvpuller's Avatar
rvpuller
If you 12KW generator won't start your home A/C I would have someone check the units start cap & Relay, run cap maybe the compressor amp draw or there's something wrong with the generator.
Denny
Old Jul 4, 2023 | 10:43 AM
  #52
cpobst's Avatar
cpobst
Denny
I should have been clearer. I have to shut off quite a few other things for it to start it. Also it's duel fuel which we know running on propane puts out less power. I have a 500 gallon propane tank just for backup purposes. Gas will be only a short term solution as I don't keep much on hand. Now if I could find a diesel/propane generator that didn't cost a fortune I'd be in business!
Old Jul 4, 2023 | 11:04 AM
  #53
rvpuller's Avatar
rvpuller
One thing you should look at your circuit balance, with everything running with a amp probe check each leg for a major unbalanced. If you do check each 120V circuits loads and shift them around to get a better balance. Generators don't like unbalanced loads.
Whenever I wired a building, house or RV park I payed close attention to getting everything as balanced as close as I could.
Denny
Old Jul 23, 2024 | 09:14 AM
  #54
kshoop1958's Avatar
kshoop1958
I'm bumping this thread started by @Great Danes to get you guys current opinion on adding a soft start kit to a single, Coleman Mach 15k AC. I'm not trying to run two AC units on 30 amps and so far I don't even own a generator. My main reason for adding one would be to reduce startup loads to reduce future maintenance, if that's legit. Secondary benefits would be lower electric cost when I'm plugged in at home, and lower noise at startup.
At $300 I was having a hard time justifying the cost to benefit, but now Coleman has their own branded version for less than $200. (Sorry, I've tried adding an Amazon link but it's not working.)
What do you guys think? Has anybody installed one of the Coleman kits? They look super easy to install using a custom bracket to fit Coleman AC units. And obviously no concerns about compatibility or voiding the warranty.
Old Jul 23, 2024 | 09:39 AM
  #55
HRTKD's Avatar
HRTKD
I don't know that you'll see any net savings on electric cost. All the other benefits are legitimate.
Old Jul 23, 2024 | 11:31 AM
  #56
MKrenn's Avatar
MKrenn
Good to know Ken. Do you have a link to the Coleman kit?
Old Jul 23, 2024 | 11:38 AM
  #57
Antonm23's Avatar
Antonm23
I recently put two Microair soft starts on my camper, both AC's on it are the Coleman Mach 15K units like you have. I can run both my AC's off a 30 amp plug now (started individually a few minutes apart of course). I've can even run both AC's off my two little inverter generators (paralleled together) running on propane (it would trip the generators trying to do that before the microair soft starts). And bonus, I can now also run one AC on my inverter (but only for about two hours before it depletes my small 400 amp hour battery bank anyway).
Overall, the microair soft starts are great, little pricey sure, but they work as advertised. Between the microair soft starts and the RV airflow vent inserts, I've spend a small fortune getting the AC in the camper working better (it's freaking hot in south Texas), but the final results are good at least.
Old Jul 23, 2024 | 01:12 PM
  #58
kshoop1958's Avatar
kshoop1958
Yes sir, here it is:
Amazon Amazon
Hopefully the link works, I've been having trouble with it! If I use Control + Left Click it works, if I just left click, it acts like it's spam?
Old Jul 23, 2024 | 01:19 PM
  #59
kshoop1958's Avatar
kshoop1958
I also installed an RV Airflow adapter, and it did make a huge difference. For the money though, I could almost buy two Coleman kits for the price of one Microair. Hard to imaging it won't work, coming from the same company.
Old Jul 23, 2024 | 01:23 PM
  #60
MKrenn's Avatar
MKrenn
Yes sir, here it is: https://www.amazon.com/Coleman-Mach-.../dp/B0CF41ZW4W
Yeah that link would not open...
