Blowing fuses
Old Apr 19, 2022 | 07:13 PM
RShirrod's Avatar
RShirrod
Blowing fuses
I have a 97 F250 7.3L Power Stroke. It sat for a while this winter and now it is blowing the #22 30 amp fuse that runs the Glow plug controller every time I try to start it. The wires going to the relay look fine (nothing chewed on). Could this be that the relay is bad? It's a 20 mile tow to the closest shop so I'd like to try and fix myself if possible. Thanks for any suggestions.
Ric
Old Apr 19, 2022 | 08:13 PM
BuddyBarnes's Avatar
BuddyBarnes
fuse # 22 is for the fuel bowl heater. Unplug it tape it change fuse and try again. It is the wire on the filter bowl with the spade connection.
Old Apr 21, 2022 | 07:56 PM
RShirrod's Avatar
RShirrod
Thanks for your help Buddy. It finally stopped raining here so I was able to check the fuel bowl. I see 2 wires going to it on the drivers side of the filter housing below the pressure regulator. Is it the upper wire or lower wire that you suggested disconnecting?
Thanks again!
Ric
Old Apr 21, 2022 | 08:24 PM
BuddyBarnes
Look for the one that has the spade connection. Not the round one. I don't remember if it is top or bottom.
Old Apr 21, 2022 | 08:29 PM
BuddyBarnes
I went and pulled my old fuel bowl out of the shop and it is the upper one.
Old Apr 26, 2022 | 07:10 PM
RShirrod's Avatar
RShirrod
Hey Buddy, Just wanted to let you know that I was finally able to get that fuel bowl heater wire disconnected. What a pain that was. But I guess it's been on there for 25 yrs
I taped it up, replaced the fuse and she fired right up.
I wish there was some way that I could repay you for your help. I was a day away from calling a tow and paying the Ford garage.
Thank you again!!!!
Ric
Old Apr 27, 2022 | 09:46 AM
BuddyBarnes
Good to hear. Glad you came back to let us know. What happened is the fuel bowl heater shorted out causing this. The heater is not needed by most and this is the quick fix.
Welcome to FTE
TNT
19
Feb 28, 2012 08:08 PM
green 69
Feb 21, 2010 10:01 PM
dustbuster_26
Dec 11, 2009 07:31 PM
D.R.800X2
15
Nov 4, 2008 10:01 PM
njstevens
Dec 27, 2007 09:39 PM
