Another Ignorant Wiring Question
Old Apr 3, 2022 | 10:07 PM
Tunafish389's Avatar
Tunafish389
+ Polarity. I had Spyder headlights that were wired same way. White - Black +
Old Apr 4, 2022 | 06:39 AM
ASFC27FTFBQ's Avatar
ASFC27FTFBQ
Originally Posted by 01__Excursion
What is your GPS switch for?
I ordered a GPS switch awhile back because I was so ignorant about automobile electronics that I didn’t know there were “switched” and “constant” power modes. So I bought a switch. The cigarette lighter plug-in I used was constant, so I had to plug-in/plug-out to keep the battery from running down.
To do it over again, I would just hard wire the GPS to my my switched fuse block and be done with it.
Old Apr 4, 2022 | 06:45 AM
ASFC27FTFBQ
Originally Posted by kabcpapc
I know I'm late to the party but what exactly are your rear lights for? Are they auxiliary backup lights?
These are lights that will help illuminate the area behind the Ex to hook/unhook our travel trailer.
Old Apr 4, 2022 | 06:50 AM
ASFC27FTFBQ
Thanks guys for suggesting a bench test of the lights to check the polarity. I have never done that before. So I rigged up a set of wired alligator clips and eyelet terminals.
You guys were spot on. In my case the white wire is negative and the black is positive. Never would have guessed.
Thanks again for the help!
DznyRulz
Mar 14, 2017 10:54 AM
ccaissie
1983 - 2012 Ranger & B-Series
Aug 10, 2016 07:47 AM
79cherro
Electrical Systems/Wiring
Aug 6, 2016 07:04 AM
GEugeneS
Sep 14, 2009 09:16 PM
ultramag
Apr 22, 2007 09:07 AM
