93 2.3L Splash light switch conundrum
Old Aug 9, 2016 | 04:19 PM
ccaissie's Avatar
ccaissie
This truck had a wiring problem when it was given to me, and a new light switch that was stuck in the dash seemed to work mostly, though I remember he said it wasn't the right one.
Supposedly, the tan-white wire (which unites to a red wire at the connector B2) carries the power to the light switch. On mine, it doesn't seem to. Fuse #10 has no power no matter what. However, a big brown wire, which is never mentioned, has continuous power to pin B1. When I jump it to the tan-white/red wire, pin B2, the switch controls the tail and front corner lights. Otherwise there's no tail light action
When I hook the big brown wire to the double brown wires, pin R, the same lights work without the switch.
When the tail/front corner lights are on, the red rear cab light is on....isn't this a brake light?
Also, brake lights are not working by pedal....they were earlier...
So, tail wiring is ok, but what's up with the power to the switch? I can't find any numbers on the switch to confirm it's the wrong switch...could that even make a difference?
Other than that, it's a swell truck, but there's some hair-pullin' goin' on.
Old Aug 9, 2016 | 07:02 PM
spooktn's Avatar
spooktn
here is a wiring link that might help !! Search Wiring Diagrams
Old Aug 10, 2016 | 07:47 AM
ccaissie's Avatar
ccaissie
Thanks, but that diagram just doesn't handle the weirdness in my system...must be a freak, or a quick fix by the previous owner.
I know the tan wht wire is supposed to be power.
Where does the heavy brown wire come from? It's at least 12ga. maybe 10ga?
I'll try for a better, contorted look, but my surgeon will kill me if he finds I'm torquing my shoulder repair. Mirror on the floor, I suspect.
C
schoo
Electrical Systems/Wiring
Aug 30, 2014 09:16 AM
travelingman55
Dec 24, 2012 11:14 PM
Iraqveteran
Nov 3, 2009 10:36 AM
bdb75
Feb 24, 2009 06:02 AM
Metalgod1919
Nov 17, 2003 04:09 PM
