1978 - 1996 Big Bronco
Codes After Cat Removal
Old Mar 24, 2022 | 04:45 PM
BRA's Avatar
BRA
Cool Codes After Cat Removal
Hey, I am new to this site, so thank you in advance for your help.
I have a 1996 Bronco with the 5.8 and automatic transmission. When I bought the Bronco, I fell prey to the thought that removing my cats and installing true duals would give me more power and better mileage. I was wrong on both of these. Before, I had no CEL and it ran great. After they were removed, I got the CEL of P0171 and P0174. This is a lean condition on banks 1 and 2, not a missing CAT. I have tried almost everything to fix this. New vacuum lines, smoke test, intake gasket, fuel pump, and filter. You name it and I probably tried it. I took it to a shop and they kept it for over a week with no help. I tried the O2 sensor tricks and nothing. I was thinking I should install some high-flow cats to see if this will help, but I was told by Flowmaster (on the phone) that this will not fix my problem. He suggested I have the CATS programmed out of the EMC. Can anyone out here help me with this? It runs fine, cranks right up, and has no issues, except that dang CEL and it does run lean. I can smell it sometimes.
Old Mar 26, 2022 | 05:16 PM
torq'ta 5 8's Avatar
torq'ta 5 8
You cant smell lean, you can smell the PCM being told by the O2's, they are lean, and PCM will dump, more gas in, your MPG is prolly, tanking right now, programming it out, isnt a fix, the problem is still there, your truck will still run like death warmed over, put it back the way it was, both O2 feed the last O2, until it does again, your issues will gradually get worse, dont mean to be a party pooper
tattooed_yoshi
May 20, 2013 03:37 PM
goosehunta
1983 - 2012 Ranger & B-Series
Apr 29, 2009 12:44 AM
RayAWheeler
1997 - 2003 F150
Apr 21, 2008 07:25 AM
hatchellc08
Exhaust Systems
23
Jul 9, 2005 02:51 AM
e g rred
Jan 13, 2005 09:57 PM
