Please Help
Old Mar 21, 2022 | 06:36 PM
Djames91's Avatar
Djames91
Please Help
I have a 2001 f350 7.3l. The truck originally went into the shop for an hpop reservoir reseal. The shop broke my timing cover by over tightening the bolt on the side of the reservoir. Long story short they refused to fix it and I took over the repair. The motor now has a new timing cover, hpop, lpop, oil cooler, cps, and oil switch. After getting everything back together and filling fluids, I topped off the hpop res, and now I'm stuck with a crank no start. The truck fires right up and runs for about 8 seconds after filling the res. I have tried doing cycles to prime the system, I have done a pickup tube test and checked to make sure the anti drain back check valve was still good. For some reason the res still will not hold oil over night and it will also not refill when cranking. Please any ideas of what to check or do. I could really use the help. I have never gotten this deep into diesel work and am beyond knowing what to do.
Old Mar 21, 2022 | 07:07 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
@Djames91 welcome to the FTE!
I literally said "oh my God..." when I read what the shop crooks did to your truck. It is too bad you had to deal with that, but lets see if we can get you going and on a more positive note from here on out.
Are you sure that they used the right gasket for the HPOP reservoir reseal?
See the link below for more details from an expert in this area. Another consideration is the LPOP, it should provide ~12 PSI at the HPOP reservoir plug if my memory is not failing me.
Link: https://www.ford-trucks.com/forums/1...l#post18944796
Old Mar 21, 2022 | 07:13 PM
Djames91's Avatar
Djames91
I used the gasket that shipped with the new cover. After the shop cracked the cover they didnt do anything else. I replaced the cover and oil cooler. When it didn't start up I began replacing the other listed parts.
Old Mar 21, 2022 | 08:14 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Look at the LPOP. Make sure you didn't put the gears in backwards against the front cover. They only go in one way (correctly). The gears are marked for proper orientation.
Old Mar 21, 2022 | 08:55 PM
Djames91's Avatar
Djames91
I used a melling pump. It didn't have any marks to orient it as directional. I was told that they only have markings if it ford oem
Old Mar 21, 2022 | 09:12 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
That would be correct. The Melling is relieved for installation in either direction.
Old Mar 21, 2022 | 11:51 PM
udsuth78's Avatar
udsuth78
Did you soak the gears in motor oil before install and did the pick up tube get a new gasket and a small bead of the Ford grey rtv?
Old Mar 22, 2022 | 09:23 AM
Djames91's Avatar
Djames91
I put vaseline around the rotors before going on and yes p/u tube got both and torqued down per specs
Dynexmidnight
22
Feb 9, 2020 08:38 PM
T_balla_me
Mar 16, 2016 08:02 AM
Leydon101
13
May 30, 2013 11:05 PM
sami001
69
Mar 4, 2013 07:19 AM
burninfordrubber
1997 - 2003 F150
Jan 26, 2007 08:18 PM
