Help please
Old May 27, 2013 | 01:55 PM
Leydon101's Avatar
Leydon101
Help please
hey Guys so i went on vacation for a week. had some work that needed to be done didnt have time to do it so i left it at a shop. they did my CPS camshaft position sensor which i bought from ford. and a oil change. first day driving back from vacation it was driving normal no more stalling (CPS) problem. all of a sudden stalled out looked behind me huge trail of oil. my oil pan bolt came off. i bought a new one went on good not stripped refilled with oil. Truck will not start. where should i begin??..
Old May 27, 2013 | 02:51 PM
bryanlindborg600's Avatar
bryanlindborg600
Make sure your hpop is full of oil about a 1/2" from the top.. and crank it in 10 second intervals to let your starter rest in between.. And I'm sure your batteries are ok but they may drain down in the cranking process.. But from my understanding these motors will shut down due to lack of oil before any real damage can occur! Good luck!
Old May 27, 2013 | 03:16 PM
stainlessstroker95's Avatar
stainlessstroker95
X2^^ check hpop oil.
Old May 27, 2013 | 03:24 PM
JWC 3's Avatar
JWC 3
It has taken me 30 min or so to get some start after low oil , injector change , or high pressure work . As stated let your starter cool off between attempts . I would also contact the shop that did the oil change !
Old May 27, 2013 | 06:50 PM
fordman67's Avatar
fordman67
Yea.^^^take the advice and you will be fine.stinks though.
Old May 28, 2013 | 12:25 AM
oldbird1965's Avatar
oldbird1965
I was cruising down the road and my little copper line for the oil pressure gauge broke. I pucked all my oil out and the motor quit. I got on here and ask if I ruined the motor and the answer was no, the PCM will shut the motor down before damage.
Old May 29, 2013 | 05:48 PM
Leydon101's Avatar
Leydon101
Thanks for the replies guys got the truck going again runs just fine. Thought I could trust a shop to do a oil change or me while on vacation. Guess if you want something done right you have to do it on your own. Thanks again
Old May 29, 2013 | 06:02 PM
rodneywar's Avatar
rodneywar
to clarify what you said the pcm wont shut down the engine when u run outta oil. you run outta oil to fire the injectors no fire no run thats the best thing about the heui systems no motor damage when u loose your oil unlike the 6.4 and 6.7s
Old May 29, 2013 | 11:38 PM
oldbird1965
Yeah Ronnie, that's defiantly a better way of putting it.
Old May 30, 2013 | 08:27 AM
bryanlindborg600
Glad you're up and running!
Old May 30, 2013 | 04:32 PM
427 fordman's Avatar
427 fordman
Did you have a little "chat" with the shop? I know I would have.
Old May 30, 2013 | 08:09 PM
Leydon101's Avatar
Leydon101
Absolutely let them knew I wasn't happy got refund. Thanks for all the replies great forum. I will be starting a project truck this summer it was my first truck I got a few years ago when I first got my license truck has some sentimental value to me and I just love this year truck for ford. Ill prob make a thread for it so everyone can follow and maybe give me ideas and tips. Ill be doing oil pan replacement removing the engine, body rust repair some other stuff. Great forums and hopefully people can give me tips on what to do while I have the truck apart.
Old May 30, 2013 | 08:50 PM
JWC 3's Avatar
JWC 3
Glad things turned out OK for you . Glad the shop Manned Up and did you right !
Old May 30, 2013 | 11:05 PM
bryanlindborg600
agreed!! we all make mistakes, it's nice to know some still man up to 'em!
carbon coupe
Jun 16, 2018 06:48 PM
Leydon101
May 27, 2013 02:52 PM
95350PS
Oct 24, 2012 06:33 AM
MiamiPSD
Mar 28, 2009 11:10 AM
AlaskaF350PS
30
Sep 13, 2006 06:28 PM
