2022 Superduty key fob programming
I bought an OEM Fob and tried to follow the instructions in the owners manual, but no luck. A big problem is step 5 that has you push the start button again (turning the truck off) after your 2nd factory programmed fob is in the slot under the console storage tray for 5 seconds with power on. The 2nd sentence in step 5 says to keep the ignition on for at least 3 seconds. How can you keep the ignition on if you were just instructed to turn it off?
I've tried programming instructions posted online for 2021 trucks, but it sounds like the 2022 might have different security. I've also noticed numerous discrepancies in my 22 manual that leads me to believe that Ford made changes in the 22, but mostly just recycled the 21 manual.
https://www.fordtremor.com/threads/k...8/#post-101151
Press start button. Once start up chime stops turn ignition off.
Swap first factory key with second quickly. Repeat above step with second key.
Factory key code should show on dash after chime stops.
Quickly swap second factory key with new key.
Press and hold start button. Dash should light up hazard lights flash and a notice on dash that key was programmed successfully.
After trying many different variations, it finally worked with the instructions posted above except I had removed the manual key out of each fob. I also worked at very quickly swapping fobs between steps. Perhaps I had my tongue sticking out the correct side of my mouth during the procedure?! LOL
