1978 - 1996 Big Bronco
Motor swap
Old Mar 15, 2022 | 02:17 PM
Dalton_buxton's Avatar
Dalton_buxton
Motor swap
I have an 87 bronco with the efi300 and a manual transmission, the head is cracked and I found a 302 out of a 95 f150. I was hoping someone could assist me in figuring out if the bellhousing will work so I know if I need an adapter. Any and all help is very much appreciated!
Old Mar 15, 2022 | 02:24 PM
AbandonedBronco's Avatar
AbandonedBronco
Hello,
Yes, they share the same bellhousing, along with the 351w V8.
Your biggest issues will be the perches that the engine bolts to. I went from a 302 to a 300 and had to cut off the V8 perches and bolt on ones for a 300.
You'll also need some other things, like a new radiator, since the ports are on different sides.
It'd probably be much easier to just get a new head for the 300. It's a bit of work to go from the I6 to a V8.
Old Mar 15, 2022 | 02:35 PM
Dalton_buxton
Originally Posted by AbandonedBronco
Hello,
I have to buy a new head and the motor has a bunch of miles already. I found new motor mounts to swap it. The used motor has less miles and I've seen it run plus I like the way they sound. I appreciate the quick response!
Old Mar 15, 2022 | 02:44 PM
AbandonedBronco
Glad to help.
Did you just find motor mounts?
Or did you actually find the perches that bolt to the frame? The perches are what the motor mounts bolt to.
Engine => Motor Mounts => Perches => Frame
If you did find perches, then it shouldn't be too bad. Be sure to get the wiring harness, too, etc.
Old Mar 15, 2022 | 02:47 PM
Dalton_buxton
I'm converting it back to carb so I don't have to deal with as much wiring. Do more work for less if you know what I mean
thefordlane
Mar 28, 2010 11:07 AM
Jbot
Oct 28, 2006 04:24 PM
Brian79150
Nov 27, 2003 01:02 PM
Cheap_hotrod
Apr 15, 2003 01:24 AM
ahickey
May 14, 2001 12:40 AM
