What Are These Brackets Called?
Old Mar 14, 2022 | 11:30 PM
HRTKD's Avatar
HRTKD
I have four of these brackets on the outside of my trailer and four on the inside. They hold an aluminum shelf/table that can be moved inside or outside.
I don't know what to call them. I need to buy two more of them, but it's hard to find them when I don't know what to call them.
Old Mar 15, 2022 | 06:45 AM
SpencerPJ's Avatar
SpencerPJ
Is there a brand name on a tag under the table / shelf ? You might have luck on a RV forum?
Old Mar 15, 2022 | 08:28 AM
RV_Tech's Avatar
RV_Tech
Is this what you are looking for https://www.jegs.com/i/JEGS+Performa...yABEgISJvD_BwE
Old Mar 15, 2022 | 08:50 AM
HRTKD's Avatar
HRTKD
Originally Posted by RV_Tech
BINGO!!! We have a winner. That's the exact part. Thanks!
I have a trailer mod brewing in my mind and I needed something like this to get the project started.
Old Mar 15, 2022 | 08:54 AM
RV_Tech's Avatar
RV_Tech
You're welcome. In cases like this it usually works to simple describe the part by its function and run a search under "images". Than search through the images and click on the picture, which is what I did in this case. I often had to find parts for which I had not idea what they were called and sometimes they were out of production. Doesn't always work, but quite often.
Old Mar 15, 2022 | 09:07 AM
HRTKD's Avatar
HRTKD
The $11 shipping cost on a $20 small part reminds me why I rarely buy anything from JEGS. I'm going to suck it up this time. I searched around with the name of that part but JEGS seems to be the only one that carries it.
Old Mar 15, 2022 | 03:26 PM
FuzzFace2's Avatar
FuzzFace2
Did you check McMasters Carr to see if they have them?
Dave ----
Old Mar 15, 2022 | 03:29 PM
HRTKD's Avatar
HRTKD
Dave ----
The closest I could find there were knurled nuts, which were close. Without the keywords to go on, there wasn't much to find.
Old Mar 27, 2022 | 12:53 PM
HRTKD's Avatar
HRTKD
In case anyone stumbles upon this thread and is looking for the dimensions of these brackets that came from JEGS, I created a dimensioned drawing. I'm not very good with CAD so the drawing is "close" to representing what the bracket really looks like. The bevel referenced by "D" isn't a bevel in the drawing because I can't figure out how to make the tool do a bevel. Measurements are accurate within about .01" using my cheap digital calipers. No, I won't provide metric equivalents. But I will say that for a couple of the measurements, they were close enough to a round mm number that I had to wonder if the manufacturer might have produced them to metric dimensions. But everything else was so far off from round mm that my theory wasn't worth much.
Crappy picture of the bracket that I received.
Old Mar 27, 2022 | 01:43 PM
Bugzilla46310's Avatar
Bugzilla46310
Thanks for taking the time to post this
adbscu
Feb 23, 2020 10:21 AM
OBX 56
Mar 22, 2018 02:03 PM
sdetweil
All Things Towing
Aug 26, 2015 08:17 AM
StreamlineGT
Connecticut Chapter
18
Jul 11, 2010 04:57 PM
Gary E
Jul 6, 2008 10:47 AM
