22s check your rear diff!
Old Mar 24, 2022 | 09:32 PM
  #106
doyall's Avatar
doyall
Originally Posted by DSLTRK60
... Interesting note is that the gas trucks call for 80-90W and diesel is the 140 weight oil. Same axle.
Not mine.
Old Mar 24, 2022 | 09:50 PM
  #107
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
FInally secured the elusive OEM M300 cover. Waiting on the bolts then will ditch the steel cover.
I think mine called for 75w-85, but 75w-90 is much more common to find and cheaper, so that’s what I went with. Won’t hurt a thing.
Old Mar 24, 2022 | 11:27 PM
  #108
cnote72's Avatar
cnote72
Great looking cover, where can I find one of those?
Old Mar 29, 2022 | 03:46 PM
  #109
DSLTRK60's Avatar
DSLTRK60
You have to look for someone selling a take off cover. As far as I know, Ford won't sell these covers to anyone by themselves.
You also will need new bolts. The thread is an M10x1.5 30-35mm long.
I went with OEM part# N803942-S439 from Ford.
Old Mar 29, 2022 | 07:54 PM
  #110
Garbageman 134's Avatar
Garbageman 134
2022 F250 Lariat 7.3 3.55 10 speed trans. How do I figure out which differential and transfer case oil I use? I tried searching with my vin, no luck
Old Mar 29, 2022 | 08:03 PM
  #111
Dustin F450's Avatar
Dustin F450
75w140 gear oul for the differential , buy 4 qts, have a bit left over. The front calls for 80w90 2.75 qts. The transfer case uses 2qts Mercon LV atf .
Old Mar 29, 2022 | 08:16 PM
  #112
Garbageman 134
Any additives?
Old Mar 29, 2022 | 08:30 PM
  #113
Scott6.0PSD's Avatar
Scott6.0PSD
I would check your owners manual. I thought the 3.55 was the 10.5 rear, which (according to my manual) uses 75w-85
Old Mar 29, 2022 | 09:15 PM
  #114
Dustin F450
75w140 won't hurt it a bit. You may loose .0001mpg. I pulled my I from from diesel truck resource. I would use Redline or Amsoil. If you have Limited Slip yes, buy the LS additive. If you have an electronic locker, don't add anything. I run 75w140 in both front and rear of both trucks. I tow heavy....never an issue. I even fo UOAs on the differential s.
Old Mar 29, 2022 | 11:49 PM
  #115
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Correct. I used 75w-90 as it’s easier to find/more common and cheaper.
Old Mar 30, 2022 | 02:07 PM
  #116
westracing01's Avatar
westracing01
Out of curiosity, does it matter which LS additive? Like do we have to use the Motorcraft stuff or will Amsoil Slip Lok work fine?
Anyone who wants OEM stuff, Rockauto has it.
EDIT: Oddly enough, if I take out the $20 renewal for my Amsoil account, Amsoil is cheaper than Rockauto by a few dollars.
Old Mar 30, 2022 | 02:15 PM
  #117
10nmbri's Avatar
10nmbri
4wd Low
I have a 22, F-250 Lariat with less than 1K miles. I have been hearing the clunk sound from the rear diff from the first day also. It is more so when you are cruising at low speeds, take foot of gas pedal and then depress it again. Feels like a play in the rear diff.
Old Mar 30, 2022 | 02:20 PM
  #118
last5oh_302's Avatar
last5oh_302
Chances are it's the slip yoke you're hearing, and that's normal.
Old Mar 30, 2022 | 02:25 PM
  #119
C12H24's Avatar
C12H24
There is play in the differential. That is a consequence of the ring gear backlash. When backlash is checked, you set up a dial indicator on the ring gear and rock the gear back and forth on the pinion gear without moving the pinion. That play allows the gears to work correctly as they heat up. Of all the differential setup specs, backlash is generally easiest to set as all you have to do is adjust the side bearings to move the ring gear closer or further away from the pinion. It just about is impossible to screw up. There is a spec range and if it's on the loose side, you would probably feel that slightly. But very slightly.
Old Mar 30, 2022 | 02:59 PM
  #120
chadstickpoindexter's Avatar
chadstickpoindexter
I've seen this thread enough that I have finally ordered 4 quarts of 75 140 and will do a drain and refill once it gets here... lol! By the time I have it, I will have about 5500 miles on my truck. I guess I'll plan to do it again around 30k.
