Spedometer help
Old Feb 26, 2022 | 05:54 PM
twayne85's Avatar
twayne85
Spedometer help
One little thing after another it seems.
2003 f250 4x4 speedometer not working right today. Stays at 0 until I'm probably doing around 40-45 mph then jumps to 75 and stays there until I slow down (probably to 10 or so) then drops back to 0 and stays there.
VSS or something else?
Old Feb 27, 2022 | 09:03 AM
twayne85's Avatar
twayne85
Drove it this morning. No DTCs, ABS light is not on, OD light is not flashing. Shifted fine and odometer was working. Using forscan I was able to read rear diff speed. Makes me think it isnt a vss problem but I got one anyway. Do the abs sensors also contribute to speedometer function?
Anybody have this issue?
Old Feb 27, 2022 | 10:22 AM
twayne85's Avatar
twayne85
3rd update. Disconnected both batteries and reconnected after 10 minutes. Key in, ignition on and the speedometer pegged past 100 and stayed there.
Old Feb 27, 2022 | 10:39 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Hey there!
My first suspect would be the VSS or the circuitry involved. You will need a multimeter as a visual inspection tells you nothing unless there is a broken/frayed wire.
Check this link and the subsequent link for troubleshooting procedures and pinpoint test: https://www.ford-trucks.com/forums/1...l#post20299580
Old Feb 27, 2022 | 10:55 AM
Walleye Hunter's Avatar
Walleye Hunter
Couldn't he disconnect the VSS and see what happens? What should the speedometer read then?
Old Feb 27, 2022 | 12:01 PM
twayne85's Avatar
twayne85
Originally Posted by Sous
Hey there!
Since it was getting a reading in forscan wouldn't that mean its functioning properly? I selected rear diff sensor, and both front speed sensors in forscan and all read the same but the dash speedo still didn't work.
When I do the gauge self test, all gauges work but the speedo goes now from over 100, down to 78, then back to over 100.
I recently greased the front right hub through the abs hole when doing brakes so I pulled it and cleaned it off just in case but no change on the dash.
The rear vss had some fuzz on it so I cleaned it off and put it back; was reading speed in forscan either way. I'll have to order one since the parts store doesn't have it but I'm still doubting its a sensor issue at this point.
Old Feb 27, 2022 | 12:12 PM
Sous's Avatar
Sous
FTE Emeritus
There may be a fault in the circuit board of the cluster or the ribbon cable may be corroded or have debris on it where it goes into the back of the cluster.
A somewhat common practice to clean the exposed ribbon cable contacts like that is to use a pencil eraser to clean the contacts, then some electrical contact cleaner to rinse them.
If FORScan shows the proper speed of the vehicle, there is an issue between the PCM and the cluster.
I believe there is a speedometer pinpoint test in the Ford Service Manual, but my laptop is not accessible at the moment.
I would like to "phone a friend" and see if @FordTruckNoob is able to help out. I believe it is in the PC/ED volume. I am 75% sure I have seen one...
Old Feb 27, 2022 | 02:42 PM
FordTruckNoob's Avatar
FordTruckNoob
"Regis, D: A constipated monkey. Final answer."
Seriously though, the answer is in the diagnostic procedure in the document I have attached.
Old Feb 27, 2022 | 03:38 PM
twayne85's Avatar
twayne85
"Regis, D:A constipated monkey. Final answer."
Thank you. Thats a bit intimidating to me though.
Double checked forscan against a gps speedometer app and they match.
Is there a transmission sensor to check out? now that it is pegged at over 100, when I am in 3rd gear around 35 mph the speedometer drops down to 78 then when I slow to around 25, it goes back to over 100.
Old Feb 27, 2022 | 03:51 PM
FordTruckNoob
Ford calls it a Hybrid Electronic Cluster. That means it is not analog and simply checking the VSS in the rear axle’s pumpkin is not going to solve your problem. You will have to go through the troubleshooting steps outlined in the document.
If FORScan shows the CANbus is communicating the correct speed, the problem is most probably in the cluster.
Sous's Avatar
Sous
FTE Emeritus
FTE'r Mark K had a comment recently concerning the VSS on the speedometer in relation to the transmission and the OSS/TSS.
Link: https://www.ford-trucks.com/forums/1...l#post20299529
Old Feb 27, 2022 | 04:10 PM
twayne85's Avatar
twayne85
Thank y'all.
Old Mar 3, 2022 | 09:55 AM
twayne85's Avatar
twayne85
Just a quick update on this. I haven't had a chance to pull the dash and check for issues in the wiring yet (this is my daily driver again) but I used the diagnostic tool on the odometer yesterday. Speedometer function on the odometer matched what my GPS speedometer was showing. Does the odometer diagnostic tool get its info from somewhere other than what the speedometer gets or is this a pretty clear indication the speedometer gauge has failed?
Old Mar 11, 2022 | 08:23 AM
twayne85's Avatar
twayne85
Update: Replaced the dash cluster with a used one and speedometer works again. Now I have another small issue with the new one and I will start a new thread to hopefully get it fixed.
1972RedNeck
Aug 10, 2011 03:08 AM
Tater0519
Apr 12, 2005 07:33 AM
Daryl Hunter
Sep 30, 2003 09:12 PM
