Sponsored by: Real Truck
Speedometer Problem
Old Apr 8, 2005 | 01:23 PM
Tater0519's Avatar
Tater0519
Speedometer Problem
My speedometer is doing something weird, hopefully, someone out here will have a solution. I have a 2000 F250 SD and the speedometer will only work about half the time. Seems like if it's not working, I can stop and turn the motor off, start it right back up and it will work. It either works fine or doesn't move at all. The odometer works regardless. Anybody seen this before? Any suggestions on what's going on? Thank you for any help.
Old Apr 8, 2005 | 02:01 PM
FordRuss's Avatar
FordRuss
I've been reading some threads where the needle was jumping around & sometimes the OD light would flash.. That seems to usually be caused by the speed sensor on top of the rear differential.. I'm sure someone will be along shortly to give some better advice..
Good Luck,
Russ
Old Apr 12, 2005 | 07:33 AM
Tater0519's Avatar
Tater0519
More Info
Another thing that I have noticed is that when the speedometer is not working, the cruise does not work either. If the speedometer is working, the cruise works. Please help.....
Ironmike86
Feb 20, 2014 02:02 PM
bigjohn57
Sep 29, 2012 07:49 AM
WhiteBroncoII2WD
Bronco II
Oct 24, 2008 11:20 AM
BrotherTommy
Electrical Systems/Wiring
Mar 10, 2007 07:45 PM
Phil Mark Davis
Sep 6, 2006 07:26 AM
