AIT Sensor Mount for 6637
Old Feb 25, 2022 | 09:57 PM
KelVarnson's Avatar
KelVarnson
I wanted a way to secure the Air Intake Temperature sensor while using the 6637 filter. I've had it tie wrapped to the master cylinder for a long time. I wanted to figure out a way to get it closer to the filter, and to shield it from heat and possible damage.
So I designed a shroud with a mounting plate, and in the base of the shroud I put in twist-lock bayonet features. So the sensor just twists in and locks, like it did in the stock airbox.
The mounting plate has strategically-located holes that align with features in the metal mesh, so four tie wraps will hold the whole thing to the side of the filter, oriented in such a way as to encourage airflow over the sensor bead.
I printed it in PET-G, which is rated to around 150F. I think it might be OK on the back side of the air filter. I've used PET-G for other parts that are near heat, with mixed results.
The irony is that after all of the time I spent designing it, I may not use it, because I was kind of planning on running a prefilter. Maybe I should just use long tie wraps that go all the way around the filter.
Anyway, here's some pics:
The part.
AIT Bayonetted in. I got super lucky and had a great fit and twist-lock feel on the first iteration.
Mounted to the side of the filter with a couple tie-wraps. There's holes for four.
Close-up. I oriented the sensor for maximum airflow.
Old Feb 26, 2022 | 01:24 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Neato!
I'd leave it on the filter and put the prefilter over it.
Old Feb 26, 2022 | 11:51 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Everything David said above!
I found a cylinder piece of plastic and hot glued it over the sensor and zip tied it under the fuse box.
Your method is clean looking and very accurate.
Old Feb 26, 2022 | 12:53 PM
F0rdc0wb0y's Avatar
F0rdc0wb0y
I’ll take two please! That’s really really cool. If it were me I might try and find a location on the inner fender next to the filter and permanently mount it. Might have to lengthen the IAT harness a bit.
Old Feb 26, 2022 | 01:57 PM
KelVarnson's Avatar
KelVarnson
Thanks for the kind words everyone. I've made a B revision, which is rotated 90 degrees. I think that orientation will work better with the harness length. It still has holes for mounting directly to the mesh, but also now includes grooves for tie-wraps that can go around the outside of a prefilter. Here's some pics of the finished print, I will post up more pics after I get it in the truck.
Old Feb 26, 2022 | 08:49 PM
KelVarnson's Avatar
KelVarnson
Installed in the truck, using tie wraps around the outside of the prefilter. This Baldwin filter seems a little bigger than the Wix one I just replaced. I don't remember it touching the master cylinder before, and there was definitely a little more interference with the hood.
Where I have the AIT sensor oriented, it is almost at the end of the reach of its harness.
cameeks
Sep 7, 2012 08:28 PM
Scaper
Apr 28, 2012 06:37 PM
StampedePSD
Oct 27, 2008 05:21 PM
i eat hybrids
Modular V10 (6.8l)
Sep 5, 2008 05:58 PM
fd1109
Jan 28, 2006 05:58 PM
