Air sensor
Old Jan 28, 2006 | 08:15 AM
fd1109's Avatar
fd1109
Air sensor
I know this has already been asked before, tried the search for 6637 and coulnt find the answer.Anyway , what is done with the sensor probe in the filter box when you change to the 6637. Thanks
Old Jan 28, 2006 | 08:23 AM
guzzle92's Avatar
guzzle92
I zip-tied it under the filter, on the bracket for the old air box.
Old Jan 28, 2006 | 10:49 AM
Kwikkordead's Avatar
Kwikkordead
I put mine in the end of the filter. SpringerPop had a great idea on rolling up some paper and use it as a lining for the inside of the filter. Drill a hole that is slightly smaller than the diameter of the sender. Get a razor knife and notch out the hole to accomodate the retainer tabs on the sender and put the sender into the hole. You have to extend the wiring about a foot to get it to reach. Remove the lining after you drill and cut.
Old Jan 28, 2006 | 10:52 AM
jtharvey's Avatar
jtharvey
Pretty much the same thing I did. Here:
Old Jan 28, 2006 | 05:49 PM
fd1109's Avatar
fd1109
Hey Guzzle92,Kwikordead and jtHarvey , thanks for the replies , good pics , one more question , what does this probe sense ? I noticed there was a sensor in the front of the grill I know one of them is temp.
Old Jan 28, 2006 | 05:54 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
They are both temp sensors. The PCM uses the sensor in the air box to know when to engage the fast idle and exhaust backpressure valve. The one behind the grill is the temp sensor for your overhead computer.
Old Jan 28, 2006 | 05:58 PM
jtharvey's Avatar
jtharvey
This one sensed the air intake temperature. Since it was originally inside the airbox, it was designed to only take the temp of the incoming intake air. The one on the front is probably for ambient air temp, to tell the EBPV when to close, when to kick up idle, when to turn on the air intake heater, etc...
Edit: see cookies's post above. Cancel what I said the front air temp sensor telling the truck to close EPBV ect... At least I was right that the one on the front is for ambient air. I didn't think about it being for the trip computer.
Justin03PSD
Apr 1, 2012 09:33 AM
tj01536
40
Jul 24, 2011 09:00 AM
SSSimon
17
Aug 13, 2010 04:44 AM
mechelement
15
Sep 5, 2009 08:18 AM
DG65
Mar 8, 2008 05:14 PM
