Where is the fuel filter sensor?
Old Nov 27, 2011 | 10:56 PM
Scaper's Avatar
Scaper
I have a 93 f250 with a 7.3idi motor. I noticed today my Fuel Filter check light didn't come on when I started the truck. Where is this sensor located? thanks guys!
Old Nov 28, 2011 | 01:40 AM
Dark Horse's Avatar
Dark Horse
It is in the Bottom of the fuel filter Here is a picture of mine off the filter
Her are 2 pictures of the inside of the filter base
Check that the wire harness is still connected to the sensor terminal in the first Picture
Old Nov 28, 2011 | 08:05 AM
Scaper's Avatar
Scaper
Thanks guys, I have found that I need a new sensor. Cheers all!
Old Nov 28, 2011 | 09:25 AM
jas88's Avatar
jas88
Well that is the water-in-fuel sensor, but there is also a fuel filter sensor on top of the filter housing. It looks like a small version of the oil pressure sender and points towards the middle of the engine.
Old Nov 28, 2011 | 11:13 AM
eatont9999's Avatar
eatont9999
The filter sensor will set off the WIF light, right? It must because my WIF sensor is unplugged and the other day I got a WIF light. I changed the filter because it most likely needed it and the light went away. Unfortunately now I am having fuel delivery issues most likely caused by leak back. No leaks anywhere and the truck started on the first crank before changing the filter. I don't get it.
Old Nov 28, 2011 | 12:45 PM
Dark Horse's Avatar
Dark Horse
Here is an exploded diagram of the entire filter assembly
There at a few more pictures in my album 93 truck parts
Ford Truck Enthusiasts Forums - Dark Horse's Album: 93 Truck Parts
Hope this helps
Old Nov 28, 2011 | 01:12 PM
jas88's Avatar
jas88
On my truck the filter has it's own light to the lower right of the tach that says "FUEL FILTER" and it's yellow.
Old Apr 28, 2012 | 06:22 PM
jlwoods99's Avatar
jlwoods99
why would someone plug my continuous vent with check valve and what does the schraeder valve do?
Old Apr 28, 2012 | 06:37 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
probably because it leaked and was the cheap and easy fix to just plug it by a previous owner.
the schrader valve lets you bleed air,and take fuel pressure readings.
the bottom sensor will yes.if the sensor is unplugged and shorts to ground it will set off a false reading that you have water in your fuel.
plug it back on and drain it every 5k miles or whenever the light comes on.whichever comes first.
the fuel filter should last 60k miles or whenever the top fuel sensor triggers your fuel filter light (not the same light as the WIF) whichever comes first.
Sous
39
Jan 9, 2018 05:31 PM
bduemig
13
Aug 16, 2010 03:17 PM
ckal704
Jan 27, 2009 06:39 AM
spazinweasel
Apr 15, 2008 04:44 PM
1SG
Oct 5, 2003 07:07 PM
