What to check with replacement engine?
Old Feb 24, 2022 | 02:51 PM
PriusLover's Avatar
PriusLover
I have an opportunity to look at a running engine on a wrecked truck. ~200k miles. Want to make sure my checklist is in order:
  • Check oil, auto trans fluid, coolant level. Look for metal in the fluids, look for oil or diesel in coolant.
  • Check air filter, turbo compressor blade condition; has it been dusted?
  • Start engine cold, take note of how hard it is to start, what quantity and color of smoke it spits out. Check cranking consistency by ear.
  • Pull codes.
  • Measure blow-by with gauge.
  • When engine is warm and Forscan gauges up, put in drive with foot on brake, rev it up and note behavior.
This sound good? Anything I'm missing?
Old Feb 25, 2022 | 01:47 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Sounds thorough!
Ask for it to be cold when you look at it. Disconnect the 42 pin connector so it will not start while listening for consistent RPMs. Ensuring good compression is prolly the most important part of the endeavor. Everything else bolts on.
Old Feb 25, 2022 | 06:40 AM
udsuth78's Avatar
udsuth78
Might want to do a cold buzz on the injectors. Could even do an hpo pressure test if you've got a IPR jumper made up.
Old Feb 25, 2022 | 10:53 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Between your list and the fellas comments above, you should be good to go.
I would like to add, take your time. If the seller is rushing you, saying they don't have time, might be best to leave it.
You appear to be a very detailed and thorough person based on your posts and threads. We are all hoping you find what you are looking for.
TrucksNCoffee
Mar 21, 2019 05:12 PM
willannarino
6.4L Power Stroke Diesel
Oct 17, 2013 09:01 PM
wnyps
Dec 23, 2007 08:07 PM
xjvince
Dec 14, 2006 03:51 PM
grtF250
Feb 5, 2004 06:54 AM
