Check engine light,surging,white smoke
"Lack of power, fluid leakage from tailpipe, abnormal tailpipe sediment, white smoke, exhaust smell, check engine light on:
The above conditions may be accompanied by elevated engine idle, surging, engine knocking or the crankcase may be over full. Fluid frome the tailpipe may be coolant, fuel or oil.
If diagnostic codes P0087, P2291, P0263-P0284, P0300-P0308, or P1336 are retrieved, or if there is evidence of an internal fuel leak (fuel in the exhaust, over-full oil), the fuel supply to the injectors and the injectors should be checked for leakage. If the oil is not over-full the turbo bearings should be checked.
If the codes are P132B, P2262 or P2263, or there is evidence oil oil leaks or the oil level is low, turbo actuator operation and turbo bearings should be checked.
If there is evidence of coolant leakage from the exhaust or the coolant level is low, the EGR coolers should be tested.
Additional codes may include P244C or P244D for the DPF. Perform diagnosis on the above codes and engine noises as needed. Care should be taken when running the engine due to the likelyhood of piston hydro-lock/engine damage."
Just wait it will get worse .
After mine I would believe anything!
I hear a lot of folks saying these are the best ever! Well I wish we could figure out the odds on who got a good one and who got bad ones. This site is for Ford PSD people not many going to say anything bad. I wish you guys could see my shop! It is FORD Everything. I am very pro F Series, but I am not happy with these so far. I think they were rushed out of the factory (Hurry get them out we will fix the problems later) I have seen this before with Ford. Quality Control at Ford is a joke. It is all about the Money (Mexico Parts) Hell my right side doors on my SC were hitting hard at the top! Chiped the paint off big time but it still got shipped like that. I have had, (as many of you have heard me complain about) many problems, keyless entry pad replaced, Rear end rebuilt, Radiator replaced, Trailer Brakes switch is bad, Doors leaked air
very bad, Hubs are being replaced next week. can't use 4x4 because of clunking noise. fuel milage went down from15.8 to 11.0, has been flashed
3or 4 times because of Regen and high idle, (Needs it again). My air filter clogged up with snow! while I was driving in a normal snow fall. Ford said they are giving me a Free winter cover! I have 12,000 mile now,have had truck since Aug. The dealer has had it much of that time
-bought Oct 5th
-back in a week later no parking lights/cant tow, short in body harness rattling driver window switch. fixed on driver door, now rattling in passenger door
-back two weeks later wont start, fixed self day later "mystery", cancell appt. that afternoon go over speed bump,passenger door window switch goes "pop" falls off (broken tabs)
-back last week "very bad smoke, crop dusted downtown herndon", not exaggerating, considered normal, no problem found... HUH?!?! perfomed tsb 7-4-11
-going back next week radiator peeing when turned off after driving/towing, oh and new passenger window switch rattling again.
Otherwise.... sure makes a pretty $60k paperweight
Sorry just frustrated.....
