Evans Coolant
Old Feb 23, 2022 | 05:11 PM
Becky_is_a_66's Avatar
Becky_is_a_66
Do you see evidence of corrosion inside the radiator or does the coolant drain out nasty looking when they fail? Maybe it’s a vibration/fatigue failure. Maybe try an isolator between the four mounting screws and the radiator support to prevent vibration from migrating to the radiator. Most modern cars with aluminum radiators have rubber idolaters where they mount.
Old Feb 23, 2022 | 05:28 PM
ibuzzard's Avatar
ibuzzard
See A Man About A Horse
Originally Posted by 654x4
I had a bung in the intake that was plugged.
Ahh, yes, very common among men of a certain age. It is treatable.
Old Feb 23, 2022 | 05:47 PM
Red60's Avatar
Red60
Not vibration per the analysis provided. Electrolysis enjoys environments where dissimilar metals exist or electric current travels. This is why aluminum boats have isolated ground and are not chassis grounded.
Old Feb 23, 2022 | 05:58 PM
stonewalljac's Avatar
stonewalljac
thats why anod's work. Gives it something else to chew on.
https://www.summitracing.com/parts/s...SABEgKaZ_D_BwE
Old Feb 23, 2022 | 06:58 PM
Christmas's Avatar
Christmas
That looks like the ticket. I'll give it a go. Thanks.
Old Mar 3, 2022 | 06:10 PM
Sortofa65's Avatar
Sortofa65
Just for info I was looking on Eckler's website and came across that they sell radiator caps with anodes in 7, 15 and 16 psi
Old Mar 4, 2022 | 05:35 PM
john jamieson's Avatar
john jamieson
Now the question is: Will the corrosion byproduct clog the newer radiators with tiny water passages?
Old Mar 4, 2022 | 06:25 PM
Red60's Avatar
Red60
So its a choice between possible clogging and an external leak? I think remote possible clogging is a much smaller risk
redz284u
Aug 16, 2021 11:59 AM
Crewcab Turbo
Dec 18, 2011 04:31 PM
abnrngr1986
6.4L Power Stroke Diesel
Dec 19, 2010 04:59 PM
whattatruck250
Jun 27, 2010 06:10 PM
