6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
coolant?
Old Dec 19, 2010 | 12:55 PM
abnrngr1986's Avatar
abnrngr1986
coolant?
do we need to mix this stuff 50/50 or use it 100% concentrate?
Old Dec 19, 2010 | 01:19 PM
sawtooth's Avatar
sawtooth
50/50 if your using the factory coolant which i would.
Old Dec 19, 2010 | 02:08 PM
abnrngr1986
thanks, thats what im using.
Old Dec 19, 2010 | 02:44 PM
ItsABeautClark's Avatar
ItsABeautClark
What would happen if you "topped off" your coolant tank with 100% coolant (adding 3/4" to max level)??
Old Dec 19, 2010 | 04:16 PM
galaxie641's Avatar
galaxie641
nothing would happen
Old Dec 19, 2010 | 04:59 PM
RoadJunkie's Avatar
RoadJunkie
If you reference the instructions on the rear side of the antifreeze container, there is typically a chart that correlates the freeze protection as a function of water to antifreeze mix. A 50/50 mix is typically the "optimum" mix for both freeze protection and engine cooling. Your anticipated operating climate should guide your decision on to what ratio of water to antifreeze you select.
oasisbenk
Oct 31, 2011 07:26 AM
flyboy2610
Jul 12, 2002 02:18 PM
KPO
Jan 11, 2002 12:16 PM
50yellowbeast
32
Nov 14, 2001 10:37 AM
whaynes
May 24, 2000 09:13 PM
