Coolant 50/50 mix help
Old Aug 16, 2021 | 08:13 AM
redz284u's Avatar
redz284u
So my truck reached 150k miles and I decided to do a coolant flush as indicated in the maintenance schedule. I know I was supposed to do it at 100k. So it came from ford with Orange coolant. I emptied both primary and secondary, and filled with distilled water. Ran truck for a week. Then drained and filled again with distilled. Ran for another week. Finally last cycle I drained, replaced all thermostats, and filled with Yellow coolant.
Question, since I was only able to drain 6 qt at a time for the secondary, and about 20 qt at a time for the primary, how do I know if my coolant mixture is 50/50? Since some of the coolant remained in the engine and the concentration of it is unknown, when I added 50/50 yellow coolant, it would dilute to less than 50/50.
What is the best way to verify I have 50/50 in there?
Old Aug 16, 2021 | 09:40 AM
aboyles's Avatar
aboyles
Test the specific gravity, something like the link below.
Amazon Amazon
Old Aug 16, 2021 | 09:50 AM
redz284u's Avatar
redz284u
https://www.amazon.com/Prestone-AF-1...24898553&psc=1
no way!!!!!!!! can it really be that easy???? Didn’t even know they made such a tool. I spent all weekend trying to calculate the mixtures. Then researched the Acustrip website which confused me even more.
Old Aug 16, 2021 | 09:59 AM
aboyles's Avatar
aboyles
Specific gravity tester is old school. Probably been around longer than both of us put together. Tells you how low a temp. your coolant can go before freezing. it is that easy. any parts store or probably walmart should have one.
Old Aug 16, 2021 | 10:01 AM
ford390gashog's Avatar
ford390gashog
Old Aug 16, 2021 | 10:49 AM
redz284u's Avatar
redz284u
Other than anti-freeze and anti-boil benefits, is there another adverse effect to having to much or to little coolant? Say I have 40/60 or 60/40, would there be any damage to the engine and components?
where I live it never drops below 30F, considering running 40/60 or even 30/70. Any thoughts on that?
Old Aug 16, 2021 | 11:12 AM
ford390gashog
You can go 70/30 max. That will give you -84 degree freeze protection and 276 degree boilpoint. Do not run less than 50/50 or you will have issues with corrosion, boil over and the potential for cavitation.
Old Aug 16, 2021 | 11:14 AM
aboyles's Avatar
aboyles
anti freeze has other additives in it such as anti corrosives. I think the minimum recommended is something like 40/60.
Old Aug 16, 2021 | 11:29 AM
redz284u's Avatar
redz284u
i thought the whole idea of it being distilled water was to prevent corrosion. If you have 100% distilled water, would it still corrode? Pardon my ignorance in this topic.
Old Aug 16, 2021 | 11:35 AM
aboyles's Avatar
aboyles
I'm not an expert by any means but I think it would.
Old Aug 16, 2021 | 11:55 AM
redz284u's Avatar
redz284u
appreciate all your help. I’m on the right track now.
Old Aug 16, 2021 | 11:59 AM
ford390gashog
Well vapor distilled water is corrosive in itself. It's just free of most impurities, oxydizers and hardness. The coolant has the inhibitors in it.
JAMSRF250
Sep 18, 2013 11:04 PM
Crewcab Turbo
Dec 18, 2011 04:31 PM
abnrngr1986
6.4L Power Stroke Diesel
Dec 19, 2010 04:59 PM
Annihilator
Dec 3, 2004 08:21 PM
