rocker arm problem
Old Feb 21, 2022 | 12:54 PM
pp 63's Avatar
pp 63
rocker arm problem
hello to all ... I come to ask you for advice about my rocker arms on my ford f 150 with a 400 engine
indeed I realized that my engine was not running smoothly and was smoking on the left side (I have two separate exhausts) after opening the rocker covers I noticed that a push rod was missing and I found it twisted in the intake plate with its tappet out of its housing .. after inspection it did not damage me .. the cause of this breakdown is due to the wear of the rocker arms and their nuts .. I ordered a kit of rockers + nuts plus new bolts .. by inspecting the other tappets I realized that the engine is off so without oil pressure they are hard and do not sink in?? do you think this is normal?? I re-soaked the one that had come out in engine oil in order to fill it up and even filled it is flexible compared to those that are in place ... should I take them all out and empty them clean them and put them back or not ?? here's hoping that I was clear enough in my questions .. thank you for your help cordially
Old Feb 21, 2022 | 01:51 PM
440 sixpack's Avatar
440 sixpack
If you're in there I'd replace all the lifters.
It's doubtful you had enough wear on your rockers to cause the bent pushrod. or if you do everything else is probably wasted as well. check the valve that lost the push rod carefully to see if it's returning all the way back up.
I bought a new f150 with a 400 in 1980 that bent a push rod when I test drove it and did it again about every 10,000 miles until it hit about 50,000 miles . I never did figure out why but I assume it was a tight guide.
Old Feb 21, 2022 | 02:43 PM
kenny nunez's Avatar
kenny nunez
Push rod
Be sure that the push rods are clean on the inside. A stopped up push rod will wear out a rocker arm. There was a 351 M at my Dad’s shop that would start up and after about 10 minutes it started to miss on #4 because the exhaust rocker would bind up. The push rod was stopped up.
Old Feb 22, 2022 | 03:10 AM
pp 63's Avatar
pp 63
Smile
thank you for your answer.. i think the rod has twisted in the tappets i will look at everything as it should i looked at the tappet and the inside of the cylinder (it is number 5) with an endoscope none damage .. what bothers me is the lack of flexibility of all the other tappets when cold and without oil pressure ..
Old Feb 22, 2022 | 09:12 AM
Mark8man's Avatar
Mark8man
Agree its not likely wear in the rockers is the problem and also agree it may be a sticking valve that caused it to throw a rod. The design of the rockers is that they do have play in them after the nut is tightened so I wonder if that's what you are seeing and think is wear?
When you had the lifter soaking in oil, you need to compress the piston in lifter with a push rod to pump it up hard. Just soaking it probably won't fill it. If you can't "pump" it up then the lifter is bad.
I would not empty the all the lifters; You don't want to disturb anything other than where your problem area is at least until you accurately diagnose why it threw a rod.
I may not be understanding your comment but a good lifter will not leak down so it will not compress when cold with no oil pressure.
Once back together leave valve covers off. Disconnect coil and turn engine over with starter while watching the valve closely. Hard to say without seeing it in person so we have to speculate, but there could be other causes.
Old Feb 22, 2022 | 06:27 PM
mark a.'s Avatar
mark a.
Too much valve to guide clearance ?
Old Feb 22, 2022 | 09:35 PM
440 sixpack
Not likely that would cause it. but he says there's no oil burning so the guides must be pretty good. maybe too good and one is sticky.
Old Feb 23, 2022 | 10:35 AM
pp 63's Avatar
pp 63
hello .. thank you for your advice ... I'm just going to put the pusher in question back and I'm going to change all my rockers I received them yesterday afternoon from the United States .. I'll let you know what happens next and you'll do some photos again thank you for these precious advices cordially .. (
Old Feb 23, 2022 | 11:27 AM
440 sixpack
By pusher I assume you mean lifter. I certainly wouldn't put the one that bent the push rod back in and it would be best to replace them all. you can always put new lifters on any cam new or used.
Old Feb 23, 2022 | 11:48 AM
pp 63's Avatar
pp 63
the rod twisted when it "descended" into the intake plate it was the action of the other moving tappets that twisted it the tappet I inspected and cleaned it has no problem against the rocker is worn at its pivot point that's why I recommended some to change them .. my engine has apparently been redone but they have not changed these parts ... however what I I'm surprised it's the hardness of all the others that are in place, even with the engine stopped and cold, no oil pressure but no play, they're hard as wood. I wonder if they shouldn't all be taken out. and disassemble them to clean them or else they have a non-return valve and at this time it is normal for it to be so ... to be continued
[img]data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAABQAAAAUCAQAAAA ngNWGAAAA/0lEQVR4AYXNMSiEcRyA4cfmGHQbCZIipkuxnJgMStlMNmeyD2d wmc8+sZgxYJd9ErIZFHUyYYD7fkr6l4/rnvmtl7+KitrqV/fq2Y5eLY3Z9S48eRLe7BmVZ9qhTLhQ0algzZWQOVKSsCF8OjAn wbxDTWFDUhPK/jMr1H6HE/IqRky2DyvCefuwItwZzodVoYRiLqMkVCXrwpJ9twZ+sgfDYEFY l8wIWxZ9uFf7zkallxlJh4YrLGsKjZRx7VGHhLqwgFUN45DGdb 8MeXGpgB4ABZdeDcpZEY51A+hyLKz4S1W4MQWm3AibWtgWmk6d yISa1pSdyWTOlLXVp0+eL9D/ZPfBTNanAAAAAElFTkSuQmCC[/img]
pp 63
Feb 21, 2022 12:52 PM
Thinlizzy13
Oct 11, 2015 03:47 PM
JoshuaHancock804
13
Dec 29, 2010 01:44 PM
ehgeeray
Feb 18, 2010 08:32 PM
77ford guy
Sep 16, 2006 05:07 PM
