Rocker Arm Adjustment
Old Feb 18, 2010 | 07:32 PM
ehgeeray's Avatar
ehgeeray
I think I read somewhere that the 6Liter doesn't have any rocker arm adjustment because the engine has a hydraulic cam following system...
Can any one confirm? Do the push rods stay slightly loose until the engine oil pressurizes?
Old Feb 18, 2010 | 07:38 PM
steelhead2's Avatar
steelhead2
the only way a pushrod will come loose is if you have a lifter losing its prime.being able to turn them is normal, but if youre getting up and down movement i would replace all the lifters, and check for wear on the pushrods and the rockers.
Old Feb 18, 2010 | 07:45 PM
ehgeeray's Avatar
ehgeeray
So when I assemble the rocker arms back in place there are no adjustments necessary? I'm use to adjusting the rocker assemblies with feeler gauges etc...
Old Feb 18, 2010 | 08:32 PM
steelhead2's Avatar
steelhead2
torque to specs and all should be good.
seafire
May 3, 2010 11:40 AM
CatFlip
Jul 31, 2006 07:58 AM
ford390gashog
Nov 1, 2004 09:27 PM
