2016 ford f150
Old Feb 16, 2022 | 03:10 PM
Lupe001's Avatar
Lupe001
2016 ford f150
Has anyone figured out why one low beam light goes out on 2016 Ford F-150 I have power on driver side plug until I plug in headlight and power to plug dies out
Old Feb 16, 2022 | 05:02 PM
SpencerPJ's Avatar
SpencerPJ
No idea, but I'd look at grounds.
Old Feb 16, 2022 | 05:29 PM
Lupe001's Avatar
Lupe001
i checked grounds and they all look good cleaned them and put them back on it’s just weird cause I have power to the plug until I plug the headlight in
Old Feb 16, 2022 | 06:01 PM
GlueGuy's Avatar
GlueGuy
If there is power to the plug, there may be an open on the ground side. I would check that the ground side is actually grounded (measure ohms to a ground reference). May be an open wire (like maybe a rodent got to it) or a corroded connection. I might pull the bulb out and clip a resistor or maybe just the blub so you can measure the voltage and/or current getting to the bulb.
Old Feb 16, 2022 | 06:35 PM
Lupe001's Avatar
Lupe001
[QUOTE=GlueGuy;20291845]If there is power to the plug, there may be an open on the ground side. I would check that the ground side is actually grounded (measure ohms to a ground reference). May be an open wire (like maybe a rodent got to it) or a corroded connection. I might pull the bulb out and clip a resistor or maybe just the blub so you can measure the voltage and/or current getting to the bulb.[/QUOTE
Yeah because I check wire before plugging bulb it has power plug the bulbs loses power and then leave it a couple minutes has power in it again I’ve tightened up the ground but tomorrow I’ll look see if I see any chewed up wires
Gunnerboy
Mar 27, 2017 12:32 PM
Jonnys.1991
Feb 22, 2016 02:11 PM
ryito1122334455
Dec 31, 2011 11:39 AM
nhawki00
Feb 15, 2005 07:08 PM
95_Ford XL
Electrical Systems/Wiring
Dec 4, 2002 08:52 PM
