Error code P1450
Old Feb 14, 2022 | 04:17 PM
brithefireguy's Avatar
brithefireguy
Error code P1450
I have a 2016 F-150 2.7 Ecoboost with 160k miles. Had the code checked and it stated it was the canister purge valve. I installed the new one this morning. I was told to drive it 50 mile and disconnect the battery. I’ve done both. Check engine light is still on. Any suggestions?
Old Feb 14, 2022 | 05:21 PM
diesel_dan's Avatar
diesel_dan
If you had a phone app like Forscan or Torque (with OBDII adapter) you could clear the code. Another option would be to go by a car parts store and have them clear the code. Then see if it comes back...
Old Feb 15, 2022 | 08:13 AM
projectSHO89's Avatar
projectSHO89
Any suggestions?
Follow PROPER diagnostic procedure to identify the actual fault instead of guessing. CANP valve is only one of multiple possible reasons for that DTC.
Old Feb 15, 2022 | 10:20 AM
JKBrad's Avatar
JKBrad
I would say more likely the canister itself. Especially if you stuff fuel in it after the pump shuts off, trying to get an extra half gallon in it.
Old Feb 16, 2022 | 11:08 PM
wgotthardt's Avatar
wgotthardt
Last week I had same dtc, same part (same 2.7L), and cleared the code after replacing (with free use Autozone scan tool). It solved the issue I was having prior (hard start immediately after fueling).
jwsrules
6.7L Power Stroke Diesel
Aug 7, 2024 08:09 AM
ogarcia434
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Oct 14, 2020 10:55 PM
RusPro
4 Cylinder Engines
Feb 11, 2017 10:00 PM
JEFFRO67
Oct 31, 2016 11:55 AM
pablocruz69
Aug 13, 2010 12:50 PM
