4.9 #3 plug
Old Dec 19, 2011 | 11:22 AM
ryito1122334455's Avatar
ryito1122334455
4.9 #3 plug
92 f150 with a straight 6
109 000 miles the #3 plug keeps coming loose i was wondering why...every thousand miles or so itll run bogged down, so i go check the plug and it needs retightened . i can turn it by hand. all the other ones are tight any suggestions
Old Dec 19, 2011 | 11:13 PM
ryito1122334455
anyone have ANY ideas?
Old Dec 20, 2011 | 06:15 AM
rla2005's Avatar
rla2005
Check the threads on the plug and the head. One or both are probably stripped.
Old Dec 31, 2011 | 02:38 AM
ryito1122334455
bump bump.....anyone else? its a new plug goes in tight just gets loose lil help....it runs bad with the plug loose i wanna know why plug is getting loose in the first place...all the others are tight infact i cant remove the first 2
Old Dec 31, 2011 | 08:41 AM
Cheggie's Avatar
Cheggie
I don't know why, but I've got one that did that occasionally on my 95 300. I bought a spark plug thread tap, and cleaned up all the holes. It doesn't seem to be a problem anymore.
The ultimate fix would be to have the plug hole drilled out for a steel spark plug insert, but you may or may not have to remove the head depending on what kind of kit you can find.
Never had another vehicle do it, but this is one of the last vehicles on the road in any significant numbers that uses the large plug thread pattern -old style spark plugs. Maybe that's got something to do with it?
Old Dec 31, 2011 | 09:28 AM
CJM8515's Avatar
CJM8515
You can chase the threads as already suggested with a spark plug tap or you can buy helicoil save a thread kit (45 bucks). The kit you drill out the head slightly, run the tap they provide thru, then you insert the steel insert and tap it down with the special tool. Ive used it before with great success-it works great.
Old Dec 31, 2011 | 11:39 AM
ryito1122334455
thanks guys
ramair428cjxr7
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Oct 31, 2018 01:31 PM
Gunnerboy
Mar 27, 2017 12:32 PM
bigcountry1009
Mar 26, 2015 03:02 PM
jspringator
Modular V10 (6.8l)
Oct 19, 2013 08:50 AM
Long Beard
Nov 29, 2011 06:24 PM
